Machine is printing faint copy what could be possible error
  • kakima Dec 14, 2016
    Hi Erick Wekesa, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Erick Wekesa
    Erick Wekesa Dec 14, 2016
    The model is km 3050i
  • 372 Answers
Try doing an ink head clean. If you give me the make/model I'll tell you how to do that.
Posted on Dec 14, 2016
  • Office Equip... Master
  • 4,159 Answers
Erick - if the printer is a laser monochrome printer.
Laser printers have too requirements. Toner and drums.
Most modern laser printers have a limited print number on the drum. Have you reached this limit of 400,000 pages .If you have a new drum will be required.
The toner may be close to empty and causing this.
4 Suggested Answers
printech
  • 159 Answers
SOURCE: Printing faint copies
clean the scan unit
Posted on Mar 15, 2008
POCBM
  • 121 Answers
SOURCE: hp2100 laserjet printer producing very faint copy
Could be a few things. I would check the transfer roller first it is the roller that sits under the toner cart. This roll should be spring loaded. Press down on each end, it should move down and come back up. If someone removed this roll the springs may be missing or out of place.
Let me know if this helps
Posted on Mar 04, 2009
  • 4 Answers
SOURCE: Xerox DC12 Problem
please have a check with the developer unit of the black color , it might not be moving.
Posted on Sep 01, 2009
Faint printing
Have you by any chance set the print properties to DRAFT? that will print a light copy to save ink and looks like what you describe. goto printer properties and select the correct mode or default.
Mar 24, 2014 | Brother MFC-7440N Multifunction Network...
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
Faint copies
Several things. If you use it as a printer and the prints are clear, then you need to clean the scanner.
If both prints and copies are light, then the laser window needs cleaned, and possibly a drum and developer.
Jul 19, 2010 | Panasonic DP-8016P Copier
Prints faint pages
Compare print copy & photostated copy, is there any difference ?
Dec 11, 2009 | Brother MFC-9440CN Laser Printer
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
Very faint copies
You need developer added to your machine. When it is added properly to the toner, your copy quality will improve.
Sep 01, 2008 | Office Equipment & Supplies
29 people viewed this question
k24674
jasbo
jasbo
