Question about Dryers
Need to replace drum belt on Maytag electric dryer. Model # SD515DAYW a diagram would be most helpful
  • 55 Answers
Hello.
Go to this link and type in your model number. This will get you the tech sheet for that unit and will show you the diagram.
http://www.servicematters.com/maytag_library/html/index.html
Posted on Jul 23, 2009
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 | Dryers
MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE WHAT COULD THAT BE??
Nased on your description, MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE, I have provided some links that may help you diagnose your issue.
1. Drum Belt
2. Drum Belt and Roller kit
3. Parts breakdown and disassembly diagram
4. Belt installation diagram
You will need to provide the model number off the product ID tag located on your dryer to access the links information. Click link number 1 to begin.
1. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i529597&PartID=529597
2. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i587636&PartID=587636
3. http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
4. http://www.affordableappliance.com/Tips/beltdiagrams.htm
Aug 24, 2009 | Dryers
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer belt replacement
maytag.gif Diagram E
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
New dryer belt is rubbing top of idler arm spring
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page look for "Dryer Belt Diagrams" under the Special Features section. There is an extensive list of dryer belt diagram illustrations available that you can print out. Maytag is listed. Hope this helps you.
Nov 11, 2008 | Dryers
Open Questions:
Dryers Logo
69 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
