Question about Cub Cadet Garden
Cub 5234d shut down like you turned key off now it wont start
  • Cub Cadet Master
  • 2,049 Answers
Check all your safety switches. There is likely one under the seat. Mine has one in the lever area that activates the blades. Also one if you don't push the clutch. to start. Mine also has one if you put it in reverse and don't release the cutting blades.I undo mine one at a time till I find the bad one. Of coarse put them back before operating the machine.
Posted on Dec 24, 2016
I have a Cub Cadet LGT 1054 It just quit running and doesn't do anything when key is turned.
If the battery is good, The pressure switch in the seat might be stuck, or unplugged, The switch shut down power to everything when you are not on the seat
Nov 27, 2016 | Cub Cadet Garden
I was mowing I have a cub cadet series 1000 was running fine all the sudden shut down and will not start acts like it has no connection. Battery is new, but still cleaned terminals. Turn key nothing
Make sure your new battery is charged up first. New batteries will die sometimes. Make sure your cables are tight and clean and your starter could be at fault if all that work it won't turn over. Make sure your engine is not seized as well.
Jul 21, 2015 | Cub Cadet Garden
How can I get an Owners, Operation Manual for a cub cadet, series 5000, Model 5234D Diesel Tractor
You can download it here:
http://www.manualslib.com/manual/33979/Cub-Cadet-5234d.html#manual
Feb 05, 2015 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub Cadet Wont Start.
Is the blade engage off? On my riding mower, I shut if off and the blade was still engaged. Drove me nuts for 3 days and all of a sudden, I got lucky.
Oct 03, 2012 | Garden
Cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Jun 09, 2012 | Cub Cadet Garden
1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
Apr 21, 2012 | Cub Cadet Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
80 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
