Question about Refrigerators
Water is leaking from the valve wher the ice comes out . How do I remove the cover and is there an "o" ring or seal to replace
Model GPC197DPSL 567liter
MrScary66613
  • 1990 Answers
SOURCE: oil leaking out of valve cover gasket
It is a Valve Cover Gasket. You can get a new one at any Auto Parts Store. To make this repair last longer, Do not get the Cheap one, Get a Felpro Gasket and it will Quadrupel the Gasket Life. Please Rate My Response! Thanks!
Posted on Jan 30, 2009
  • 10865 Answers
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
Posted on Apr 27, 2009
philbran
  • 242 Answers
SOURCE: how to remove water dispencer cover
you must start at the bottom prying the plastic off carfully with a flat head screw driver.
Phil
Posted on Jun 11, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
  • 127 Answers
SOURCE: I have a single handle shower valve by Moen. Water
there is a clip holding the cartridge in place. You need to remove that and then there is a little plastic throw away tool that comes with a new cartridge that you use to break the seals loose on the old cartridge....then you use a pair of channel locks to grab the stem and pull it out. The new cartridge should come with detailed instructions.
If it is a moentrol valve...the part number is 1225 and if it is a posi-temp it is a 1222. Moentrol you pull out to turn on and then left and right for temp adjustment. Posi-temp just turns to turn on and you turn from cold to hot to adjust through the temp range.
Posted on Dec 05, 2009
Oil leaking on spark plug
If the spark plug is oil fouled, you either have leaking valve seals, or bad piston rings. Bad rings would be accompanied by excessive blow-by. With the engine running, remove your oil filler cap. If there is air pulsing out of the filler tube, it your rings. If not, it is your valve seals.
Jun 15, 2016 | Cars & Trucks
Cars has oil where spark plugs are inthe bottom
you must replace the spark plug tubes seals along with new valve cover gasket. Remove the valve caver and flip it over , remove and replace the old tube ring seals with new and replace valve cover gasket the reinstall and tighten down.
Nov 30, 2012 | Cars & Trucks
On driverside of engine, oil leaking out around where I call the back cam ( one closet to firewall) at end. I am talking about opposite end from timing belt on engine. If I removed cap ( w/two star screws...
That seal typically comes with a pack that includes all the cam bearing seals and the valve covers seals. It very easy to replace. Remove the valve cover and discard the old seal, remove the old cam shaft bearing cap seals. Replace the bearing cap seals and the valve cover seal and replace the cap and cover. Tighten the bolts to about 30 lbs and that should resolve the problem.
Feb 17, 2011 | 1998 Volvo S70
Leaking hot water seal
leaking around handle?Turn water off under sink.remove handle,cover plate,unscrew valve stem assembly,and turn the two pieces apart to expose o ring,and replace
Jan 27, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
We change the spark plug of my aveo 2004, and we found out that there is a oil leak on the third cylinder, what may cause the problem?
The valve cover has rubber o-ring seals that fit into the valve cover and seal oil out of the spark plug wells. Over time, they get hard and shrink, allowing oil to enter the plug wells from the top of the engine. You need to remove the valve cover and replace the valve cover gasket and o-ring seals. The seals should come with the valve cover gasket set.
Hope this helps,
Dave
Jul 03, 2010 | 2004 Chevrolet Aveo
Plastic hose connection to water valve is leaking.
The fitting is called a John Guest fitting. It has a couple of o-ring seals inside. Once the tube is pushed into one end it is locked in. To remove, push in on the tube (opposite of what you would think to remove) then hold down on the ring around the tube, then pull out. There is a good description on this website below
http://www.johnguest.com/
Apr 18, 2010 | Kenmore 73503 Stainless Steel Bottom...
Too much smoke coming from the exhaust
chk your PCV valve. If faulty it will allow oil to be sucked up and burned. Its the critter stuck into the valve cover and has a rubber hose on it. Good
luck, Ned It's an easy fix and inexpensive. So not to panic.
Sep 09, 2009 | Mitsubishi Lancer Cars & Trucks
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Vehicle is 1999 T/C Limited (3.8L, V6) Leaking in 2 places.
Hi Briseno,
Solenoid pack leaking,
Cooler Lines to Radiator leaking,
Timing cover leaking,
They suggest changing the water pump at the same time as the lower rad hose, timing chain, and valve cover gaskets. This is because it either looks like the water pump will die soon, preventative measures, or the shop is trying to rip you off for an hours labor.
Either way, I would suggest taking it to a mechanic, unless you're a bit of a handy man.
Hope I've helped, don't forget to rate.
Lazaruselite
Feb 24, 2009 | 2000 Chrysler Town & Country
Frigidaire Side by side Leaking water from Behind the dispensor
You may have a defective water inlet solenoid valve. replace water inlet solenoid valve for ice maker. Contact Frigidaire Dealer for part by Model and serial number. Replacing the part is reverse of removing old valve located behind refrigerator on right side facing the back. You may have to remove bottom back cover to access. Make sure you reinstall the cover for proper operation.
Apr 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
