Question about Hardware & Accessories
I have a old Electronic timer (arlec) controlled by Pins & setting the clock to switch on and off. I need a instructional manual. Please help?
  • 944 Answers
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual page 7 Hope this helps :)
Posted on Mar 17, 2007
SOURCE: Instructions to re-set timer
Press and hold down the "clock" button. After about 5 seconds the display will start blinking. Press the "hour" to set the correct hou, "minute" for minute. Once done, press the "clock" button once more.
Posted on Jan 02, 2009
  • 1723 Answers
SOURCE: Intermatic pool pump timer, time clock won't turn
Check your wiring, it sounds like it's not right. The clock needs 120 volts to run.
Posted on Jun 30, 2009
SOURCE: Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Posted on Nov 01, 2009
SOURCE: Westinghouse photoelectric switch 28KC,# E257484 outdoor timer.
Here is the manual!
The Westinghouse 28451 is the exact same timer. I found the manual online.
Posted on Oct 29, 2011
How do i set arlec pc 899 powerpoint time ??
Q1. How to set on / off times?
A1. Shift the red actuator pin to the desired on time
shift the black actuator pin to the desired off time.
Q2. What is the shortest time interval?
A2. 15 minutes.
Q3. Maximum switching times?
A3. One "on" and one "off" setting.
Q4. Can you override?
A4. Yes, use the override switch.
Note: If the main power is turned off the timer will need to be reset.
To set the timer to the current time you will need to turn the dial in a clockwise direction until the smaller arrow (Line) on the front face is pointing to the current time.
Arlec Customer Service
+61 3 9982 5111
Dec 10, 2014 | Audio Players & Recorders
Arlec 24hr timer PC607
I would start by turning on the lamp,if switch is not on lamp can not get power when timer comes on.
Nov 29, 2013 | Hardware & Accessories
Simple instructions on how to operate an arlec timer switch which is older style and manual. It plugs into a power point.
Timer is not identified. Read through possibles options below:
Add a comment with simple description of the timer for possible identification of product and possible instruction.
If you have analog dial timer, then open following link for instructions:
Following link shows a variety of arlec timers: each timer has instruction manual that expert can access. Add a comment and say which of these timers is same-similar to your timer, and then say what part of manual is confusing.
If you already have instruction sheet for timer, then add a comment and describe timer, and include what part of manual is confusing.
If you want expert to speak with you about programming the timer, then request fixya phone assistance. Expert can ask which timer you have, and answer specific questions while you program timer.
Sep 08, 2011 | Hardware & Accessories
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
I have a GM 40 Series Multi Voltage Commercial DPDT time switch .Voltage reading across L1 L2 is 240. Orange and green light are both energized wired NO COM water heater not turn on.
Online manual for GM40:
You own a high-quality time piece.
I have defrost versions of same timer and have tested aspects of the timer, and own few FM1 series clock mechanisms for various projects.
Complete run down for setting GM40:
1) For 240Volt the dip switches are set: Please set dip switches before applying power to timer.
2) Line wires are the Hot wires from breaker box.
Line wires connect to terminals L1 and L2N
3) Load wire are wires that go from the timer to water heater.
4) Jumper wires are short lengths of same gauge wire.
5) There are many ways to wire GM40 timer
Open manual and look at wiring diagram titled: Controlling one 240VAC (Dual Phase) Load
6) A jumper wire is added from terminal L1 to COM
Another jumper wire is added from terminal L2N to COM2
7) Load wires going to water heater are connected to NO and NO2
8) Following image shows typical FM1 timer dial:
As timer dial rotates the pins move small red switch that turns Load on-off.
Move pins in-or-out to control Load.
9) If you are uncertain about your pins, then set 20 consecutive pins one direction and then manually rotate dial and watch green indicator light turn on-off.
Put tester across NO and NO2 terminals and check when 240V turns on.
10) If you have defective timer, contact Intermatic:
11) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 27, 2011 | Intermatic 7 Day Electronic Timer Eh10...
I just bought an older electronic Intermatic timer at a yard sale. Model ET7215C. Timer power can be 120/240/277. There are 5 terminals for this, numbered 1-5. Looks like a variable tap power transformer....
I think you have the ET70215C SPDT
If this is not your timer, then add a comment.
Manual for ET70215C (same manual is for other models too)
Just as you figured, timer has selectable voltage.
Page 28 shows wiring diagrams and jumper settings:
Timer comes with a jumper, and then you select with voltage by installing jumper
Sample wiring diagram below shows 120Volts:
ET70125 appears to have 8 terminals.
Some models have 5 terminals.
There are many ways to wire this timer. Off hand I can think of 10 different ways.
Add a comment if you need help with a specific project.
In any case, the clock terminals are 1 and 2.
To put voltage to the timer switches in the simplest wiring options, is to put a jumper wire from terminal 2 to 3
If you are using 240-277 voltage with two hot wires, you still need to jumper from clock terminals to switch terminals. For example one jumper wire from terminal 2 to terminal 3 & then second jumper wire from terminal 1 to terminal 6
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Intermatic Hardware & Accessories
How do you set the timer on Malibu 300 watt transformer, ML300RTW. I have the pins in the right spots, but the timer doesn't go around. I there a on/off switch to activate the unit?
Make sure there is power to the plug. Then set the clock and install the on and off pins to control the lights. The on/off switch is for manually turning on the lights. The clock should run as soon as it's plugged in.
Jul 01, 2009 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Hardware & Accessories Logo
66 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
