The coffee basket does not register to set maker to start automatically
Eventually after sliding basket back and fourth it works
cammedic
  • 667 Answers
SOURCE: I forgot to place my coffee filter back in the coffee maker
Just an idea, but you could use a turkey baster to remove some of the water first. I doubt if you've harmed the coffee maker.
Posted on Jan 11, 2008
Wasprey
SOURCE: GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Posted on Dec 28, 2008
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
  • 199 Answers
SOURCE: My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Posted on Jun 23, 2009
SOURCE: Filter Basket pops open while grinding and brewing
Clean all the moving parts with a kitchen grade cleaner and then flush with water and air. The mechanism gets gummed up with coffee and gooey liquid over time.
Posted on Feb 05, 2010
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Need to replace coffee basket on coffee maker 13500Z
I solved the problem by using a galvanized washer to hold up the basket.
Jan 04, 2010 | West Bend 13500 Coffee Maker
Our bunn coffee maker is leaking and we don't know why. is there something we can do to find the problem and fix it ourselves?
Is it leaking from the front or back? If its leaking from the basket area, try cleaning the channels where the basket slides in and out. If its leaking from the fill area, check for cracks.
Nov 09, 2009 | Bunn NHB Coffee Maker
Very little coffee is coming out of my filter
Hi
If you are using the basket with the black ring in the bottom, it is probably getting plugged up with coffee residue. If this is the case, try using a pinch of automatic dishwasher detergent in the basket with no coffee. and brew like normal, but stop it when it starts to come out the spouts. Let it set for a couple of minutes and then repeat the process. Do this about 5 or 6 times then brew like normal and see if it doesn't clear. If it does, rinse the basket and brew 4 or 5 blank shots (no coffee). Then try to make a coffee. If it doesn't work the you might have to buy a new basket.
Oct 20, 2009 | Solis Crema SL-90 Espresso Machine
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
I was trying to clean my cuisinart DGB-600 coffee maker. I unscrewed asmall hex screw under the black piece that slides out and a spring popped out. This spring helps keep the filter basket door button...
I think the main problem with this machine is that the grounds fly all over inside when grinding and combine with the steam and hot water and eventually gum up the moving parts. This causes the latch for the filter basket to lose its grip sometimes and the door pops open during the brewing cycle...I was trying to take apart the slides to clean them out and made the mistake of removing the small screw underneath the left slide. Then the spring popped out and it took about an hour to get it back together, very frustrating. I ended up bending one end of the spring into a slight hook with a needle nose pliers so it would catch better on the "nub" that is connected to the side button. The best way I figured out to clean the slides so far is to blast them out with compressed air periodically for preventative maintenance. I use one of those cans normally used to dust off electronics and insert the straw into the slides.
Sep 23, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Register my Coffee Maker online
Description: Buy 'Pro Line Series Coffee Maker' online from HomeClick. Pro Line Series Coffee Maker - KPCM050 Please Choose Color Finish (Additional images Available), Available in Onyx Black & Nickel Pearl Product Features, Makes 12 Cups, Die Cast Metal Construction, Stainless Steel Heat Pump & Brew Basket, Digital Brew Timer & Clock, 24 Hour Programmable Timer, Front-Fill Reservoir, Automatic Shutoff, Audible Alert Tones, Time Since Brewing Display, Quiet Finish Brewing Display, Ion-Exchange Water Filter, 2 Year Hassle Free Replacement Warranty
Feb 29, 2008 | Washing Machines
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
Inherited coffee maker I have a Faberware ?138? Automatic Peculating Coffee Maker I inherited from my Grandparents. It's in great shape but I have no idea how old it is. It's a great little unit, but...
There realy not much of a manual for this type of coffee maker. put water in to water line, put coffee in the metal basket, put the lid on the metal basket, put lid on the coffee maker, set it on the stove until it starts peculating let do it for 10-min then stop.
Sep 06, 2006 | Faberware FCP412 Coffee Maker
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
