4 Suggested Answers
SOURCE: Kenmore top loading washer 70 series
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Posted on Dec 13, 2007
  • 32 Answers
sounds like you need a new motor
Posted on Dec 18, 2007
  • 1937 Answers
SOURCE: I need direction how to remove Kenmore washing machine clutch
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
You don't have to remove the agitator(s) to get to the clutch.
You do have to take out the bolts that hold the agitator(s) to the main spin shaft inside the drum. The main spin shaft is part of the transmission.
You also don't have to remove the Spin Tube and Brake assembly.
It is a lot easier to remove the transmission if you lay the washer down on its' back.
Posted on Oct 17, 2009
How to remove clutch sanyo top loading washing machine
The last time I did a Sanyo was many years ago. I didn't know Sanyo still made washing machines. I would doubt you could buy just the clutch and drive gear anymore. I would imagine you have to buy the whole transmission assembly. If this is the case, It would probably be cheaper to buy a new machine.
Nov 22, 2017 | Washing Machines
Healthstream HS1100 Rower - after 2 years use pulled out and no tension and no wind back
probably find that the rewind spring has broken the end off and the spring needs replacing
Mar 13, 2016 | Exercise & Fitness
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
Will the serial number of the waterrower enable WaterRower to know whether a waterrower without any monitor can have a monitor attached without the owner having to drill any holes into the machine? I...
Good Afternoon, ABC9363:
You may buy with confidence. There is a retrofitting device available so that all units can fit the S4 monitor. You will find it here:
Part number WRP- C110S4 is the computer backplate assembly.
Happy Rowing!
May 17, 2011 | Water Rower WaterRower Classic Rowing...
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
About 3 years ago i bought a kenmore model 665.16264400 dishwasher Never did clean very well.Now upper rack does NOT clean at all. Arm rotates freely,water inlet tube appears clear at end and engages at...
why did u wait for 3 years? if it would be me i would have brought the machine back straight away,,,,what stop u? go in touch with store or company and complain.....u may get some help
Mar 11, 2009 | Dishwashers
Need Kettler Kadett HKS-Selection Rowing Machine User Manual
Try this address. there is usually manuals at the company homepage.
Jan 02, 2009 | Kettler Mondeo Elliptical Trainer
Dec 10, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
