Hpw do I set up a MXT LCD1501 screen 14.5 inches diagonally Does it connect to my computer and does it need tp be plugged into a TV anttena
2 Suggested Answers
  • 1745 Answers
SOURCE: I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Posted on Feb 26, 2015
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Circumference to inches
40 inches is the diagonal measurement of the rectangular shape of the screen, when you say circumference , you may be asking for the area of a rectangular object with a diagonal measurement of 40 inches.
Feb 20, 2014 | Computers & Internet
Mxt tv
go to http://www.partselect.com/ and get it
God bless you
Jul 19, 2013 | Televison & Video
My sony tv 14 inches model. KV-14jrs in when you switch on the picture shown is black with horizontal line. What could it be the problem?
Line left to right in middle of screen is a vertical circuit failure.
A solder connection, a bad chip in that area----14 inch set not likely to be worth the cost of repair.
Apr 16, 2012 | Sony Televison & Video
Pink and green diagonal lines rollng across the screen??? panasonic 42" Plasma . Only purchased about 3 years ago - but been used very rarely.
Have you tried lifting the ground on the TV? That set has a grounded (3-prong) plug and sometimes sccrolling lines can be caused by a ground loop in your power lines.Are the green and purple lines very short, like just a few rows of pixels tall, or multiple inches, like 3 - 8 tall?
May 04, 2011 | Panasonic TH-42PZ800U Plasma TV
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Can't program the tv to go past channel 14 should the tv be on ant-A or cable
TV -if your using rabbit ears or anttena on the roof.
Cable -if you are a cable subscriber
Aug 04, 2009 | Televison & Video
Is this TV DVD ready or do I need a Converter Box?
Im thinking no. but there is a way you can be sure. look under your menu settings. if under the input settings you see anything about dtv or hdtv you should be ok. the simplest solution is to do a channel search. if you only come up with whole number channels ie, 3, 12, 16. you will need a converter box. if you get channels such as 3.1 12.1 or so on then you will be ok. if you need a converter box. no worries about the price. the government has cupons avalible to offset the price by nearly 80%. simply go to google or ask and type in converter box cupons. the box its self is a breeze to set up. simply plug it into the wall. plug yout anttena wire into the plug on the converter box marked anttena. then take the cord supplied and plug it into the other male connector and into your tv. turn both on and tune your tv to channel 3 or 4. everything should come up. the remote also has a set of tv controls on it.
Jan 12, 2009 | Polaroid TTM-2003 Combo
Trying to hook-up analog converter....tv has built in VCR does this pose a problem
The converter box with go between your anttena and your tv using a coax cable, the cable should have come with the converter box.
The anttena should be plugged into the input on the converter box and the tv plugged into the output on the converter box.
Sep 08, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
