Question about Garden
My till roll paper won't automatically wind onto the spool after a sale
2 Suggested Answers
CoachDave
  • 14 Answers
SOURCE: need diagrams on how to wind line onto brushcutter
Howdy Geoff,
There are basically 2 basic types of spool heads that are wound. This link will walk you through both types. Once you've successfully wound it once, it's not too difficult. http://community.homedepot.com/t5/What-s-New-in-our-Garden-Aisles/Replacement-String-Trimmer-Head/m-p/151/highlight/true#M4
Coach Dave
Posted on Oct 27, 2011
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Clear paper jam pcr t2000
It\'s very unusual for the paper to jam as this machine uses a clam shell type of printer. Just raise the printer arm and remove the paper roll. Clear any paper from the print head and roller etc. Tear any wrinkled paper from the roll and then refit the roll with the shiny side of the paper towards you. Lay the paper in the printer and close the printer arm down onto the paper. If you are setting the journal side, wind some paper onto the takeup spool after it exits the printer and sit the spool into place.
If anyone needs a Casio PCR-T2000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Jul 08, 2014 | Casio Parts Cash Register PC Desktop
When I insert a new roll of film into my Canon Rebel S 35mm SLR, it automatically rewinds the film instead of winding it onto the spool. I can't figure out why it's doing this.
this is normal, as these cameras are designed to wind the entire film to the take up spool then as you expose the file will roll back into the cassette. this was a feature that canon devised to protect already exposed film when the back cover is inadvertantly opened.
Aug 17, 2013 | Canon EOS Rebel X 35mm SLR Camera
Replacing starter pull cord on 77 20hp mercury
Remove the starter housing from the top of the motor and see if the spring broke or back wound it's self when the rope broke. If all is well remove the rest of the rope from the spool by feeding it back thru the guide hole the handle rests on. Wind it out and find a hole drilled thru the spool and put a punch thru it to lock the spool in place against the spring pressure. Remove the old cord. If it has a steel hook glued to the anchor end you will need a real mercury part. If it has a knot. your in luck.
Take your new cord and burn one end and roll the cord to a point while it is still molten. Tie your knot and heat it till it is cooked so it won't untie itself. Feed the pointy end thru the spool and out the front of the housing. Tie a knot it it where the handle would go. Gently feed the rope on to the spool when you remove the punch.
You will have more rope than the spring could wind. so untie the end knot and feed it back to the spool and put the cord in the notch of the spool so it won't rub on the housing and wind a few more turns into the spring .
When it has enough pressure to completely wind the cord up. put the punch back in the lock hole and feed the cord out the hole thru the handle and knot it, then cook that knot as well.
Sep 16, 2012 | Boating
My tec ma 1450 register won't work just blinks 0.00 and none of the keys work
With paper loaded properly, turn off/unplug register, turn MA or Service key to "Blind" position (approx. 5 o'clock), turn on/plug in register. "Status-C" will print on the receipt. Some of these TEC's won't reset after changing paper, and this procedure becomes necessary after each installation of a new roll of paper.
Jul 18, 2012 | Computers & Internet
I bought a royal 710ml that the paper is not winding on the roller is there a setting for this or is there something wrong with it, it prints but just won't wind
No there is not a setting..where the paper gets wound on to the empty spool there should be a small rubber wheel sticking out that makes the spool turn and take up the paper...have a look and make sure it is turning( or is actually there.) it could have worn right off. It should be sitting just under the spool at one side.
Jun 19, 2011 | Office Equipment & Supplies
I have cash register machine name : towa sx 680 how can i change both the rolls Kindly tell me in steps i shall be very thank full to you Regards
Open the flap in front of the printers. Press the release button inside. The paper holders will pop up. Sit the new roll in with the paper coming from the bottom of the roll. Pull some paper out to the front of the machine and close the paper holders. For the journal roll, you will need to thread it onto the black takeup spool and wind it over a couple of times, then drop the spool in the holder. that is the best I can do for a description. If you need more information, the Towa / Geller SX-680 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Towa_SX-680_operation_programming_manual.html
May 22, 2011 | Casio Parts Cash Register PC Desktop
RIBBON DOES NOT ROLL FLAT ONTO SPOOL
The first thing i would do is to install a new ribbon.
DickyO
Mar 28, 2010 | Nakajima Office Equipment & Supplies
My cash register is not printing.
Hi.
If it is a thermal printer, make sure you have the paper coming from the bottom of the roll, not the top. If you have the paper the wrong way around, it will come out blank.
If this is not the problem, please let me know the model number and any other information you can give.
Mark
Dec 08, 2008 | Casio Parts Cash Register PC Desktop
Ribbon empty
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
