Question about Apple iPad Air
How to teel the differences between an enabled / disabled volume controls on your iPad Air and what to do about it?
I'm having trouble with my iPad Air volume control button icon on my new iPad Air it shows the volume marg on how high and low the volume's going but it doesn't show the volume icon the volume margin at all it just shows the margin on high and low the volume sound is getting at all. As in the volume icon above the volume margin bar doesn't light up at all on my iPad Air at all equally but the volume margin showing how low / high the volume's getting does. Do you know what this is and how t o deal with it / fix it / what to do about it ?
  • 846 Answers
SOURCE: Ipad speaker volume is very low
Does it show a little "locked" symbol when you're trying to max the volume? You may have accidentally activated your volume limit. http://www.makeuseof.com/tag/guide-setting-ipad-part-2/ If you excluded those issues, and you actually have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Apr 26, 2010
  • 16 Answers
SOURCE: How do you unlock the rotation on an iPad? I've
Use the following steps to enable screen rotation lock:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Posted on Jan 04, 2011
SOURCE: Can I adjust the volume and equalizer on songs in iTunes library on ipad like I can on my pc?
Yes you can, however it is not within iTunes. It is under the settings in the iPod section. Here is a link to someone who has posted instructions with pictures. I hope this helps.
http://www.askdavetaylor.com/get_find_ipod_itunes_equalizer_ipad.html
Posted on Nov 16, 2011
  • 19 Answers
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Posted on Dec 08, 2011
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Posted on Jul 16, 2012
How do I enable my disabled Apple I D
You will have to go to Apple's website and verify your information. If not, contact Apple using chat or call them.
May 17, 2016 | Apple iPad Air
My iPad Air has been disabled because I forgot my password. How can I enable it again?
If you plug your device into your computer and boot up iTunes on it, look around and find a reset button click on this and your tablet to reset it. Resetting is the only way to re enable your iPad.
Aug 04, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
Aug 12, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
Volume icon appears in the middle of my iPad 3 screen and won't stay off.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Apr 30, 2014 | Apple iPad 16 GB 3G Tablet PC
Upside down screen on ipad
The Auto-rotation setting must be disabled. Enable it on the settings menu. Or if your tablet is running iOS 7, then enable auto-rotation on the Control Center. Simply swipe up from the bottom of the screen to launch control center. (It is like the opposite of pulling out Status Bar or Notifications Bar above.)
Apr 22, 2014 | Apple iPad 2 Wifi 16GB
Can i Erase face time from my iPad
You can either disable or restrict FaceTime on your iPad from the settings area. Check out the link below for detailed instructions: http://www.imore.com/how-enable-and-disable-facetime-iphone-and-ipad
Jan 30, 2014 | Tablets & eReaders
My mini ipad says disabled how can i enable it again?
Did you mean that the iPad is disabled for many attempts of passcode? Usually, waiting for a particular time span can enable agin the iPad. But if does not enable back again even after a few hours, then consider restoring your iPad in iTunes.
Apr 04, 2013 | Apple iPad Mini
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Ipad speaker volume is very low and it says in the control panel that it's full volume Any idea on how to fix this?
Feb 12, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad Air Logo
32 people viewed this question
Top Apple Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
John mullen
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
