Question about Coffee Makers & Espresso Machines
I have a problem with my machine is not biuld enough pressure to froth milk
    Top Expert:
  • Coffee Maker... Master
  • 49,266 Answers
Google it , find the manufacturer's website and ask customer support or tech service .
Posted on Dec 14, 2016
  • 944 Answers
SOURCE: No Pressure
fill the reservoir overnight with a half-half mix of white vinegar and water, then run it for a few minutes until it boils, try and turn the knob for the frother. turn the machine off and let it cool enough to empty the vinegar solution out, rinse a few times including running to boiling, and hopefully the calcium buildup which is almost certainly causing your problem will be cleared. if not, try again with 100% white vinegar, and if you can figure out how to take the frother nozzle and/or arm off the machine then soak them too. Hopefully this will get you frothing again :)
Posted on Mar 19, 2007
SOURCE: saeco milk island - no froth
Molly -- re: position of grey plug. I don't think this makes any difference at all. The key issue is to make sure those two slots are clear of debris or moisture. One month on and I have continued to achieve thick frothy milk purely from rinsing the milk island parts under a running tap, leaving them to dry, and then giving a short sharp blow to the two slots in the valve before reassembling.
Good luck
Guest with Solution 2
Posted on Apr 20, 2008
  • 515 Answers
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
SOURCE: milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Posted on Apr 30, 2009
SOURCE: the steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Posted on Feb 14, 2010
Testimonial: "Thank you very much for the advice. I adjusted the black tube and the frothing is back!"
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
Feb 15, 2011 | Nespresso Aeroccino Automatic Milk Frother
The steam wand is bubbling the milk, not frothing
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Hot water doesn't have enough pressure to froth the milk. descaled but still no froth! Thank you
If you have no steam then it is possible that the steam booster boiler is damaged, or the thermostat tripped.
Jan 11, 2010 | Gaggia Titanium Espresso Machine
Lack of pressure from the steam wand used for frothing the milk.
Hello Juneyjune,
These coffee systems have a series of small rubber 'O' rings that tend to crack from condensation over time causing your low pressure problem.
The 'O' rings are connected to a heater that looks like a horse shoe mounted in back of the grinding unit.
I would recommend contacting Miele technical services. They can have a technician come out to replace the 'O' rings or you can order them from the technical services rep if you know someone that can replace them for you. Just be careful. These machines operate off of 220 volts and that is no fun to get shocked by. I have been many times with this machine
Good luck!!!
Sep 06, 2009 | Miele Coffee System
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
