Question about Simrad Boating
Simrad nss12 not powering up
Works OK when plug in at shop but not on boat. changed all fuses & checked all cables.
3 Suggested Answers
  • 86 Answers
SOURCE: i have a minn kota 42pd/c. boat shop installed
It is needed. I usually install 3 amp fuses. It sounds like you have a short somewhere. I would trace the wiring and make sure it did not get the sheath cut and is possibly contacting the boat. I always install a fuse and that eliminates the threat of a fire. There is a reason that the fuse is blowing and if you remove it then you move the problem straight to the battery and you will most likely see smoke. Also if you dont install the fuse the equipment factory warranty will be void. You really just need to check out the wiring carefully. If there is no problem with the wiring then there is a problem with the unit and should be exchanged.
Posted on Aug 02, 2009
SOURCE: simrad ac10 current overload
I think the AC10 is maxed out at 15 amps while the AC42 goes to 30 amps. Iknow the AC10 is better with solenoid systems and the AC42 for reversing motors.
Posted on Oct 16, 2012
I went out to the continental shelf fishing in depth of 250 meters . My echo sounder is a simrad nss evo 16. I had problems while drifting the sounder would freeze how can I fix this
I did a search and found this as I don't own one not sure if this forum will help or not but thought I'd pass it on anyway.
Best to you.
https://www.thehulltruth.com/marine-electronics-forum/645739-problems-simrad-nss-evo2-chirp-structure-scanner.html
Jan 11, 2018 | Simrad Boating
Simrad nx40 master reset
http://test.new.simrad-yachting.com/Root/kimberly/NX40-45_IM_EN_MN000790_C_w.pdf
Setup --> System --> Factory Reset
If you download the manual, you can search it with CTRL-F. Search for Reset brought me to the instruction above.
Aug 28, 2017 | Simrad Boating
I want to enter my name on my simrad cx 34
check with your LOCAl boating license agent
Apr 28, 2017 | Simrad Boating
No pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Wire to trailer plug doesn't work after I replaced it.
check the fuse under the hood driver side bet a dollar thats it
May 07, 2009 | 2006 Ford Escape
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
GPS/Fishfinder keeps dropping and restarting
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Jan 27, 2009 | Simrad Ap1601r Elect Only Ap16 Rc36 Rf300...
Boating Logo
132 people viewed this question
Top Simrad Boating Experts
Steve
Steve
ray gallant
Don A
Don A
Are you a Simrad Boating Expert? Answer questions, earn points and help others
