Question about HP LaserJet 5200 Printer
HP 5200 printer . Coming out only blank paper. Toner is good What is the problem ?
    Habit-Forming:
    New Friend:
  • 54 Answers
Dear, first you need to check laser scanner shutter door, then remove the toner from printer, you can able to find right side 3 pins covering with plastic plate, check it is normal fixing or not,
Normal : when you remove toner u plastic plate will come up, unable to see 3 pins,
abnormal: when you remove toner only 3 pins get highlighted plastic plate will get down.
just re fix plastic plate covering with 3 pins it will work 100%
Posted on Aug 08, 2017
  • HP Master
  • 1,915 Answers
The shutter that covers the laser may not be opening. I have had the arm that opens the shutter break. The printer does not have a way to detect this error so it thinks everything is fine because all the laser operation sensors are inside the laser assembly itself.
Posted on Dec 18, 2016
Altoire
  • 24 Answers
SOURCE: HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Posted on Dec 31, 2006
crayzeetrayn
  • 837 Answers
SOURCE: Lexmark E321 Laser Printer
Check pages 76-80
Posted on Dec 07, 2008
EPIJAB
  • 89 Answers
SOURCE: Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Posted on Jan 08, 2009
emjem74
  • 162 Answers
SOURCE: Why will the HP Laser Jet 1020 not print?
this is a usual problem with the early models of printers. if you go onto control panel and then printers for the properties then print test page. if this prints fine then you will have to use the add/remove programmes to remove printer software. then delete the printer and install again but not from disc as windows has a package which will do it for you. leave disc in drawer and dont run. just search for the drive whilst installing printer. if this doesnt solve your problem then use the software which you will have to install again. if this doesnt occur then take cartridges out and check if they are correct ones or compatibles as hp not too compatible friendly due to counters.
Posted on Feb 25, 2009
  • 55 Answers
SOURCE: Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Posted on Apr 25, 2009
Printer not printing at all paper coming out blank
Try to Cleaning the cartridge contacts or to change toner
Sep 19, 2015 | HP OfficeJet 6110 All-In-One InkJet...
Hp laserjet 5200
firstly check whether the problem is internal or external-
Have the printer print out the config page- if you can see the image then the issue is external to the printer- check your PC settings
If you cant see an image-
You say you have allready changed the toner unit, was this before the fault or after?
under where the drum/toner cartridge sits there should be a Black 'transfer' roller that will line up with the drum surface when inserted- if this is missing or failed then the image cannot be ' transferred' from the drum to the paper. this is just one possibility, if your not sure wheher the transfer roller is working - stop a print half way through- remove the paper and toner unit - slide the drum surface protector to the side and look at the drum surface for a latent reversed image in toner on the surface of the drum, if you can see an image the problem lies with the transfer element, if you cant see an image then it could possibly be the charge chorona/ HVT PWB / Laser unit, main Pca, power supply hope this helps
Mar 11, 2014 | HP Hewlett Packard LaserJet 5200 Printer
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
Am trying to print but it comes out black blank paper
If the whole page is black then the drum unit has failed and needs to be replaced.
If the page is coming out blank remove the toner, shake it and replace. the toner may simply have hit a air pocket.
Regards GM
Jul 01, 2011 | HP LaserJet CM1312 All-In-One Printer
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
Paper jam hp laserjet 5200
All printers after sometime the rollers start grapping more than one sheet that result in paper jam or dirt building up inside…make sure you open the printer and clean it good and see if you can locate any small papers that usually stuck inside…let me know
Please do not forget to rate the service for the site to continue helping everyone and improve on it.
Sep 16, 2009 | HP LaserJet 5200 Printer
HP LASER JET 1020 PRINTER...print with nothing word
take the toner out and check to see that it is full and ready to use
Jul 20, 2009 | HP LaserJet 1012 Printer
Blank printin on the right middle ohe paper
Toner may be low. Check the Toner level. You may have to clean the printer too if you have a new toner cartrage installed. You might also have a bad printer where its not able to fuse the toner in that area any more.
Apr 22, 2009 | HP Office Equipment & Supplies
77 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
