Question about Samsung Office Equipment & Supplies
I have dirty copies from my samsung 406 laser printer, how do i get clear copies again
5 Suggested Answers
  • 208 Answers
SOURCE: Title misleading: not a printer at all
Wow you are correct there.
This looks to be a tricky use of words, it is called Multi-purpose not multifunction.
Thats extremely interesting but here is the marketing info.
Sorry you were mislead on that one.
Marketing Information The SF-560 laser facsimile is a multi-purpose office solution that combines the power of Samsung technology, with a combination of faxing, copying, and scanning. The stylish and compact SF-560 is easy to set up to immediately tackle your most demanding office needs.
Posted on Dec 20, 2007
  • 26 Answers
SOURCE: Dirty Copies
dirty print fron laser 1010 familiy printer ?
THIS IS A PROBLEM OF YOUR TONER
1. If new print cartridge toner is giving dirty print this means your toner is not original or one of it part called PRC primery chargin rod need to be replaced, If PCR is main cause it repeats dirt marks after every 1.5" inches .
2. If PCR is not a problem then dirt is due to you wiper blade of your toner .
3. last one is your toner powder used by refiller is not up to the mark.
if not solved mail me again
Posted on Jun 10, 2008
  • 9 Answers
SOURCE: ML3050 Samsung Printer
Replace drum unit an blader from toner but you can purchase from eBay cheaper than you repair toner.
Posted on May 19, 2009
rumthebum
  • 20 Answers
SOURCE: Dirty copy when scan through ADF
clean the all glass areas and also use compressed air to blow out the adf area on top and underneath the part you lift up, normall there is a white strip underneath try and clean that good with air as well.
Posted on Jul 26, 2012
Copy is a black line
If copying from doc feeder the glass may be dirty. Run a copy on the glass if no line then clean the doc feeder glass.
Aug 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Hi all expert, i got problem with Canon imageCLASS MF4150 All-In-One Laser Printer.the promlem is,print and copy out not clear even i replaced new toner inside..
if the problem is PRINTING and COPY, the problem will be in the fuser [FM2-8891-000] FUSER (google it).
sometimes they keep dirty sticked to the rollers and when the paper pass trough take from there.
Fosg22000 Rate Me, please
Mar 17, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Copy is not clear
if copy is not clear.that this can be due to many reasons.--- 1)The drum must have gone faulty or may be the drum is at the end of its life and need replacement.---- 2)The toner powder inside the cartridge or the drum has caught moisture.replace the cartridge and check.------- 3)if everything above is okay then the laser beam inside the laser assembly has dust on it causing shaded image and distorted copy.in that case the printer needs to be serviced and laser ccd device needs to be cleaned properly.-----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 24, 2010 | Samsung SF-565P All-In-One Laser Printer
My samsung ml 1610 laser printer is working but in printing pages or not clear.. in toner drum are pour by some black dust at every print even though i clean it again it come.. but still my printer not...
The problem may be the toner cartridge itself. You may need to get a new toner and clean the printer, again. Once the printer is clean re-place the new toner cartridge.
Jan 06, 2010 | Samsung ML 1610 Laser Printer
Printer Error "Toner Exhausted". How i can clear this problem. i used Ssmsung SCX-4828FN Printer.
Reset Your Printer through Reset Software which works for next 5000 copies printed. You have to reset again and agian after every 5000 copies printed. visit for solution www.nakshatraworld.com
Oct 05, 2009 | Samsung SCX-4828FN All-In-One Laser...
May 19, 2009 | Samsung ML 1510 Laser Printer
Aficio 1085 - fuser
you need to cheack your electricty source must be 220 ~ 240
Press clear modes, 1, 0, 7, and press and hold clear/stop/ Enter copy sp
and off and on the power. If something in the fuser is bad, it will do it again. If it comes to ready, then the thermister is probably dirty
Apr 29, 2008 | Ricoh Aficio 1085 Laser Printer
Dirty Copies
clean the ink box from printer where the cartidge park
Mar 20, 2008 | HP LaserJet 1012 Printer
29 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
