The earth for the main switch on a rogerblack running. Machine
2 Suggested Answers
  • 76 Answers
SOURCE: tripping main power switch
it needs a good ground to your panel if that doesnt work check size of breaker required
Posted on Aug 30, 2009
Forgot to open water supply for my new washing machine and when it started flashing I only realized the problem.As soon as it washes it trips my main switch and says Earth Leakage????Please help!!!!!
Hello Dora,
An Earth-leakage circuit breaker (ELCB) is a safety device used in electrical installations with high Earth impedance to prevent shock. It detects small stray voltages on the metal enclosures of electrical equipment, and interrupts the circuit if a dangerous voltage is detected.
You should have an appliance service person come out for a service call since there may be a dangerous shock hazard present on the machine.
Thanks,
Mario
Apr 17, 2016 | Washing Machines
Hi I have had fitted a newlec extractor fan in my shower room.
It should have been fitted by an accredited electrician because it is an IP rated unit used in a wet environment and should have an earth wire fitted to it which normally is not with a light switch
depending on the electrical regulations for your area the earth wire could be run from the metal body of the unit to an earth wire connection in a power point (gpo outlet)
but a talk with an electrician would be the safe way to go.
Aug 07, 2015 | Dryers
Why is not running ?
Do not turn anything on if your home is not earthed . Turn off main isolater and contact an electrician asap.
Aug 07, 2014 | Hoover Washing Machines
Ground leakage detected device cut the power
Take wires out of plug and the wire from the connecter box of machine. With multi tester test earth to live and earth to neutral. If there is a short circuit it will show on which wire it is. Next disconnect live and neutral wires from motor and run test on all wires. If no short the motor is faulty and test the motor connectors. If the short is not found the motor is not the problem but the control system. Disconnect all wires from controls and test everything isolated and individually.
Apr 16, 2013 | Washing Machines
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
Aug 04, 2012 | LG Washing Machines
Problem with my Rogerblack treadmill
i av gold treadmill model ag10302 and need 2 get mains lead
May 17, 2012 | Exercise & Fitness
Roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Apr 30, 2009 | Exercise & Fitness
Bosch WFB2005 triping mains
get yourself an insulation resistence tester and put one lead on the earth pin of the mains plug select continuity on the tester and touch any bare metal on your machine it should beep. After put the lead that you connected to metal on the live pin of the plug close the washer door turn machine on.Now select 500 v on the tester and press the ideal range must be above 2 meg ohms with a minimum of 0.5 ohms if you get a reading below then you have a prolem with the washer, but if above 2 meg ohms it maybe your mains socket. Good luck
Mar 02, 2008 | Washing Machines
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
