Question about Blomberg Washing Machines
My Blomberg washing mach. model WNF6300 keeps showing Co1..2..3..con..cof on display and the temp cannot be changed.I tried to press the two buttons with the lock together at one go it won t start .
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
SOURCE: machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Posted on May 15, 2009
SOURCE: blomberg washing machine
I have a blomberg washing machine AAA rating with "fuzzy logic". Now it is not working, will not fill with water or spin, but you can see the dial turning and going through the dial settings. Whats wrong. Can anyone help and I have lost the manual.
Posted on Aug 29, 2009
SOURCE: My washer will not start. I press the start/pause
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Posted on Sep 12, 2009
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and...
sorry have no info on this model have you tried draining the mach manually then switch it back on i have seen this type of prob on other makes main control board is sometimes required
May 07, 2014 | Washing Machines
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
Apr 08, 2013 | Blomberg WM87120 24" Front-Load Washer...
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
I have just changed the brown control board and now i have a fault code 9
Hi and welcome to FixYa. I am Kelly.
You did not provide a make and model number so here is my best model to problem guess....
Your new control board is missing the size information.
AQUASMART-SIZE-SETTING. Size information must be programmed when a Motor Control Module or Display Module has been replaced. If the size is not set, the display will show fault code 9, or the water levels and wash actions will be incorrect. If the machine displays fault code 9, the machine must be switched off at the wall and then back on again before it can be sized.
Setting the size:
Unplug at the wall and then re-plug it in.
Press and hold Temp Up, then press Power. Wait for the 4 beeps, then set your machine size as follows to YOUR machine size:
5/5.5kg machines - press Temp Up. Cold led should light.
6/6.5kg machines - press Water Up. Low water led should light.
7/7.5kg machines - press Spin Speed up. Spin hold led should light.
Power off, try a programme.
Thanks for using FixYa!
From the Tech Sheet:
IWL12 and GWL 11 are different models. One of the two procedures will work for your machine.
The machine size must be set into the machine
memory if a Motor Controller or Display Module has
been changed.
To set the size:
1. Turn the power on at the power point and off
at the console.
2. IWL12 - Press and hold the FABRIC CARE
button, then press the POWER button. This
will present a set of options in the LCD
screen. The LCD screen has within it a
number of options. Push the Adjust button to
highlight the 650mm (L) machine size.
Pushing the POWER button will lock the size
into the module’s memory.
GWL11 – Press and hold the WASH TEMP
UP button then press the POWER button.
Press the SPIN SPEED UP button (the HOLD
LED should be on.)
3. Press the POWER button to return to normal
Mar 20, 2010 | Washing Machines
Mi washing maching said test
It seems that Your Machine is in Test Mode.To Fix this, you need to follow the below steps ;-
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 23, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Blomberg Washing Machines Experts
Level 1 Expert
Eric Taylor
Are you a Blomberg Washing Machine Expert? Answer questions, earn points and help others
