Question about Miscellaneous
Hi, I have a 1997 Hyundai Accent 1.5 Rs - There is a petrol smell from the inside and under the engine bay. There is no indication of any petrol leaking or any marks that there is petrol escaping.
Petrol vapor smell...
  • Brett Duxbury
    Brett Duxbury Dec 14, 2016
    Hi philip , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    check the rubber pipes that run the petrol - check the point where it connects to metal pipes or engine parts. Do this while the engine is running and the car is in neutral and park brake is on. You may need to tighten the screws on the clamps at these points
  • philip
    philip Dec 14, 2016
    Hi, I have checked all connections and even the metal petrol filter. Followed all the lines that could see in the engine bay. have not went under the car. The petrol smell start when putting in petrol from half way to full. it is at its worst when full.???
    Top Expert:
  • Miscellaneous Master
  • 48,346 Answers
From your statement , the leak is from a hose connected to the tank directly
it could be a problem EVAP system , vent valve , cracked hose or cracked filling hose or air bleed hose back to the filler
Petrol is almost invisible to the eye in small quantities but using talc powder sprayed on any suspect part will show as a dark or pink stain
At this point I suspect the EVAP and canister so run the fault codes first to see if thee is a fault recorded in that area
Posted on Dec 14, 2016
I want to know torque specs for hyundai accent g4eh engine main and bigend torques
torque hyundai accent Questions & Answers - Fixya > Forum > Tags
Torque specifications for cylinder head 2000 hyundai accent Are you aware that ... cover gasket on my 1997 Hyundai Accent GLS (engine code G4EH, 1.3L).
Hyundai Alpha engine - Wikipedia, the free encyclopedia
WikipediaG4EH in a 1999 Hyundai Accent L ... lb·ft (132 N·m) at 4000 rpm, although some websites quote the torque rating as being 97 lb·ft (132 N·m) at 2700 rpm. ... 1992 Hyundai S-Coup? LS specifications - · 1992 Hyundai S-Coup? GT ...
[PDF]AERA Torque Specs
AERA Torque Specs. 500 Coventry Lane, Suite 180, Crystal Lake, IL 60014. Toll-free Technical Hotline: 1-888-324-2372 (1-88-TECH-AERA). 815-526-7600 fax ...
Torque Specifications - AutoZone
AutoZoneTorque Specifications. Print. Specific to: Hyundai ... Specific to: Hyundai Accent2006. Hyundai Azera 2006. Hyundai Elantra 2006. Hyundai Sonata 2006.
Club Accent Qu?bec • Consulter le sujet - hyundai motor s
Dec 29, 2015 | Hyundai Cars & Trucks
Put a new in tank fuel pump in 3 days ago in my hyundai accent, but can smell petrol inside the car.
I would double check that your fuel tank is sealed. Fuel fumes can be very bad for your health and can be very dangerous. Sounds as though the gas line may be leaking, or the fuel pump seal is leaking.
Nov 11, 2013 | Cars & Trucks
1997 hyundai accent loss of power
by removing the cat converter and not fixing the fault you have created more problems for yourself
all you had to do was have the fault codes read to find the problem
running rough and over heating cat indicates flooding from problem injectors or excessive fuel pressure
Nov 26, 2017 | 1997 Hyundai Accent
My check engine light is on and wont go off. I would like to put my Hyundai Accent on a diagnostic test but cant find the port. Do you know where it is or is there one?
it should be within 1 foot of the steering wheel. get down and look under the driver side it is a fair size plug and should be easy to find
Nov 29, 2010 | 1997 Hyundai Accent
1997 hyundai excel
we found some contacts in front of engine that controls the petrol flow cleaned them up and had no more problems.
Oct 08, 2008 | 1997 Hyundai Accent
Paint code for blue hyundai accent pony 1998
try this:
Hyundai Paint Color Code Location:
[1997-Present models]
  • Usually found: Driver side door Jamb (6).
  • Other place to look: inside engine bay area by Firewall (middle) (3), or Radiator Support (front middle) (10) , or Under Driver Seat (5).
    [Before 1997 models]
  • Usually found at: Driver side door jam (6).
  • Other places to look: Firewall (middle) (3) (Excel) (Scoope), or Radiator Support (front middle) (Sonata) (10).
  • Click here for diagram Paint Color Code Looks Like:
  • They are usually shown as a two digit number on the vehicle, such as PV or E8 .
  • Click Here for Hyundai Paint Color Code Label Sample
    Sep 13, 2008 | Hyundai Accent Cars & Trucks
    Hyundai accent 1.3 manual 1998
    id say your linkage in the engine bay has disconnected at the gear the bars that run from your gear stick right under the car to the gearbox
    Aug 28, 2008 | Hyundai Motor 1998 Accent
    on the petrol engine it is directly below the alternator
    Jul 22, 2008 | 2002 Hyundai Accent
    Miscellaneous Logo
    22 people viewed this question
    Top Miscellaneous Experts
    Andy Fraser
    Andy Fraser
    steve cannon
    Level 1 Expert
    Dan Grod
    Level 1 Expert
    Are you a Miscellaneous Expert? Answer questions, earn points and help others
