Question about RCA Video Cameras
RCA 4462 button will not work I dnt know what going on. Everything else works. The mic is still good. But when I put the tape in all I see is "Tape" and when I press the REC button nothing at all. He
  • RCA Master
  • 5,412 Answers
RCA 4462 is actually the catalogue number for a vinyl LP by Brian Auger - are you sure you have quoted the correct model number ?
Posted on Dec 14, 2016
SOURCE: Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Posted on Nov 23, 2006
  • 3 Answers
SOURCE: "REMOVE THE CASSETTE" displays when I put in a tape.
Same problem appears on another thread at
villagidit posted a solution there that worked for me.
The same problem exists apparently on the ZR200 which is where villagidit found the solution.
Basically all it involves is thumping on the side opposite the display. I tried the thump once with no effect. I gave it two more thumps and the problem went away. Not really a solution. But it was satisfactory for me to be able to get the camcorder working long enough to transfer all my DV video onto DVDR..
Seems something comes loose in these Canon camcorders (presumably a connector of some sort.) There are 10 votes for this solution on the other thread as of 5/19/2008.
Posted on May 20, 2008
SOURCE: Tape problem, Elura 100
I called the factory and they said to send it in for evaluation.  While packing it up, I dropped it and lo and behold it started working.   Even though it started working, I decided to send it in to the factory and they found something "loose" inside and repaired it at no charge.
Posted on Nov 19, 2008
  • 3 Answers
SOURCE: Tape is stuck in my Sony handycam DCR-PC101
I have managed to eject my tape by powering 4.5 V the little motor which drives the eject mechanism.
Problem is that you have to dismantle half the camera to do this (be very careful with the flexy wires they are fragile) and I wouldnt' do it without the service manual.
Posted on Dec 24, 2008
  • 154 Answers
SOURCE: canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Posted on Mar 27, 2009
RCA 4362 button will not work I dnt know what going on. Everything else works. The mic is still good. But when I put the tape in all I see is "Tape" and when I press the REC button nothing at all.
This was manufactured in 1999 - this makes it at least 17 years old. If I were you, I would wish it a happy retirement, and replace it with a more up-to-date camcorder with better optics, a digital image capture system, and which is far lighter in weight and more portable.
Dec 14, 2016 | RCA Video Cameras
I have an rca portable radio tape and cd player RCD175, and it plays good, but wont play cassette tapes. I put the tape in and press pas and the play button wont stay pressed in. What causes that?
It is due the mechanism trouble to your set. The casette tape deck mechanism should be troubleshooted. It is a skilled work. Just contact any experienced service technician to make this set right.
Feb 28, 2012 | Audio Players & Recorders
Can't get cd player to work in my ub802 mixer.what am I doing wrong.I have connected it via RCA cable from cd player to mixer tape in .is this correct.I also have the mixer in tape out and phantom...
Phantom should ONLY be on if using CONDENSER mics or a DI box requiring phantom power... yours should be OFF. cables should be correct. The 2 Trk to mix button should be down.
Jul 04, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I'm running a tape player into one of the mic channels, then out the tape out; problem is any stereo presence is lost. Is it possible to run a 1/8" to RCA in the RCA in, route that to the level meter/main...
Each mic channel is MONO. You could use a 1/8 stereo splitter cable into two mic channels and then PAN them opposite to retain the stereo.
You can also use a splitter cable into the 1/4 inch stereo inputs on the mixer. The 1/8 inch plug must be a stereo plug that then splits to two RCA plugs or two 1/4 inch plugs.
Note that the manual specifies that the Tape/CD out is merely paralleled off the mains out. This means that your main fader controls the level to the CD/TAPE output... which may mean your main output has to be too loud to get adequate output from the CD/TAPE outs to be effective. This would require balancing the levels into your external amp better.
Aug 05, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Feb 03, 2009 | RCA VR639HF VHS VCR
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Equalizer connections
Usually you hook your equalizer between the pre out and main in RCA jacks and then open the connection between the pre and main with a switch. If your unit doesn't have pre out/ main in jacks then I have seen it done by putting your equalizer between the tape in and tape out jacks and then select that tape function on your front panel. The tape out goes to eq. in and the eq. out goes to tape in. Good luck.
Jul 25, 2008 | Sony STR-DE485 Receiver
No sound from tape player
HEY EVERYONE WHO HAS A PROBLEM WITH A RCA RS2640 STEREO!, if u have this problem all you do is take it apart and then find the control panel and get like a credit card or something, you should see a chip placed near the control panel all you do is get the credit card and gently scratch it with a credit card for 30 seconds and then it should work!!
Jun 26, 2008 | RCA RS2640 CD Shelf System
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
Video Cameras Logo
63 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
