Question about Vertex Radio Communications
I have a Vertex vx-2200 that will transmit but will not receivie and transmissions. Any ideas?
5 Suggested Answers
Neto
  • 123 Answers
SOURCE: vertex radio vx 10
Maybe with the drop the radio speake is out of place, did try to open the radio and find if the speaker is in its correct place? The speaker uses a spring connector and this can be out of place. Good luck
Posted on Jun 22, 2007
  • 3 Answers
SOURCE: Vertex programming problems via USB
This probably doesn't help, but sometimes a much slower (older) computer will work where a faster (newer) will not. The Motorola's are notorious for this. Others, too. USB is USB, a standard--so that's not your issue.
Posted on Apr 20, 2008
randy54156
  • 55 Answers
SOURCE: Vertex headset
Why not just get a differant radio capable for beacons. 406mhz is what they've changed to.
You used a part that was not compatable with your radio. The VX-150 has a differant size plug than the VXA-150
You'll need to take the radio to repair or bend the jack back to the size for the appropiate headphones.
Posted on Nov 11, 2008
itsourcer693
  • 34 Answers
SOURCE: Vertex VX 400 reprogramming.
Yes you need a firmware program for that. Do you have a local shop in your area?
Posted on Jan 05, 2010
Can receive but not transmit successfully, any ideas?
Tough call. could be the antenna but if someone transmitted with a bad antenna it might have ruined the output circuit. the receiver will still work if the output circuit is damaged. Verify the antenna and its wiring first.
Another possibility is the microphone switch. the push to talk switch might have a loose wire and its not activating the transmitter when you push the side in.
Sep 02, 2015 | Vertex Standard VX-1700 FCCver. HF...
On programming a vertex 2200 series using the CE82 program error_2 with a beep keeps on displaying how can this be corrected?
See what Operation systems needs the programmer.
You have to open the port of your PC.
It´s a Laptop or a Desktop?
USB Port?
tell me more
Dec 16, 2014 | Vertex Cd Vx-2200 Vx-2100 Series...
I have 4 vertex VH-160 radios, two of them have stopped transmitting, all have been dowlaoded witht he same frequencies. Batteries are good. Whe transmit buton is pushed, the is one beep then nothing. ...
The VX 160's may have bad oscillators. It is not user repairable. The simple thing to check are the antennas. Vertex radios are very susceptible to broken antennas and will not transmit. This is true of Uhf and Vhf. Replace one and try it on all the radios. Never transmit without a antenna. It can cause the PA in the radios to fail.
Jan 06, 2014 | Vertex Radio Communications
How do i put a program in to my Vertex Standard VX-929 VHF 136-174 Mhz radio handheld portable transceiver
Nice commercial quality radio. You will need a commercial radio shop to program it. Otherwise you need the particular programming cable and software for that radio to do the job. The fact that you are asking this means that it more than likely it is beyond your area of expertise. If you searched the web for programming software and also programming cable you might succeed . Otherwise order both from Vertex USA, www.vertex.com. Much easier to go to a shop, BTW you need a valid FCC business or GMRS radio license to transmit.
Dec 03, 2013 | Vertex Radio Communications
Vertex 2200 transmits but makes no sound
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Dec 01, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
Ce-82 For Vx-2100 Vx-2200
The software changed to add Narrowband programming. 3.01 is fairly new, what issue are you having? Do NOT run this on Windows 8, even Win 7 has problems.
Apr 20, 2013 | Vertex Cd Standard Ce-82 For Vx-2100...
My vertex vx-2100 receives but will not transmit
Hi Rich,
Here's the solution to your query: join yahoo group specific to your radio Make/Model, the team of experts will only be to pleased to assist you, plus you can have downloads, free.
I hope this sets you right.
Best regards,
Peter
Jan 07, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
Vertex ce82 on my laptop says ce92win power on radio trying to program vertex 2200 mobile radio
Hi Shawn,
The problem is on the screen for you to see.....
You need to downgrade your CE OS to Win CE82, else you r Vertex software won't work, but downgrading is futile, so unless you can get hold of a friends Pocket book PC running Win CE OS 82, you may have problems.
This is a Win CE Operating System fault rather than Vertex software fault.
You say laptop, Win CE OS is for the smaller Pocket Book PCs as far as I'm aware.
If you're running that OS on a laptop PC, that can cause you lots more problems.
I hope this answer clears up the issue a little.
Regards,
Peter
Oct 21, 2012 | Vertex Vx-2200 Vhf 50w 134-174 Mhz 128ch...
Radio Communications Logo
127 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
