Hi. I have Yaskawa CIMR-VCBA0001BAA drive. My problem this fault code F13.36, and the ALM, & DRV led flashing. Than after Hbb error code writing. I don't know what is this. Plese help me.
MakikiChris
  • 84 Answers
SOURCE: Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Posted on Aug 12, 2007
SOURCE: WRITE PROTECTION ERROR
when i pluged the usb it shows ,but the space on it is 0 bytes.
Posted on Sep 15, 2008
worldvet
  • 859 Answers
SOURCE: Hi I have a Flash Drive 4GB it says it is write protected when
This is a bear of a problem with Transcend owners. You need to use their new Jet Flash format utility. So before doing so, copy everything off your drive to a folder in My Documents. This tool will then format your drive so you can start adding new, more organized data of your choice.
Then, try to remember to keep your data on the pen drive below the 4GB limit. This all has to do with binary math and base 10 math. The drive really doesn't hold 4GB of data, its way lower than that around 3.6GB. So, keep this in mind and keep this format tool around for future use.
I found this download link here, which is dynamic and not static but should work by clicking here.
Should that not work go to this referrer page here. You will have to start by select your product type and then go down through each selection list until you find your model and then the downloads for it will be listed. Click on the Jet Flash utility download eventually.
Personally, I think they could have done this much better and made this way simpler for consumers to find the formatting tool.
Let me know if you run into trouble and if you don't hear from me in 24 hours click on my user name and send me an Ask Me message, I'll get that message and I'll be glad to help you out.
Regards,
Worldvet
Posted on Jan 20, 2009
SOURCE: E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Posted on Feb 18, 2009
protek480
  • 1723 Answers
SOURCE: i have a fault code on a yaskawa varispeed f7 drive
Go to this link for manual.
http://www.e-mechatronics.com/en/product/inverter/f7/catalog.html
Posted on Jun 26, 2009
List of code error for honda accord sm4
If your 1989 Accord has an EFI engine, then your PGM computer (under the passenger floor carpet) will flash fault codes, through the LED light on the computer.
For self-diagnostic procedure, turn the key to ON and observe the LED flash sequence.
The following table shows the early LED type codes:
Nov 01, 2011 | 1989 Honda Accord 4 Door
F7 written in ac and shutdown after 5 minute
What error code is displayed? Status of indicator lights? Solid on or blinking? The owner's manual has a comprehensive list of error codes and solutions. Your problem could possibly be corrected by adjusting the settings.
Here's a link to the manual: Chapter 6 will help you tremendously.
http://www.yaskawa.com/site/dmdrive.nsf/(DocID)/AHUG-5K3LNL/$File/TM.F7.01.pdf
Sep 11, 2011 | Inverter Yaskawa F7 Drive
I NEED YASKAWA MANUAL IN PDF MODEL NO: CIMR F7 U42P2
http://www.yaskawa.com/site/DMDrive.nsf/536df907f9fe9d5586256c4e0056b851/86256ec30069e43286256cd700570246/$FILE/TM.F7.01.pdf
Best regards
Jan 26, 2011 | Inverter Yaskawa F7 Drive
Which type of the frequancy refferance source is given to toshiba make inverter VFA3N-8075PY-A70 ? which is used in teijin seiki winder in textile machinery.
Replace VFA3N-8075PY-A70 with CIMR-AT2A0040 & PROTOCOL CONVERTER!
Yaskawa inverter can replace the inverter with communication converter.
We have the solution on it, also TORAY T3 spindle inverter.
Fell free to contact us.
James park hyundai-sys@hanmail.net
Jan 17, 2011 | Toshiba Satellite U400/U405 Power Inverter...
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
Fault display as OPE06
OPE06
PG Opt Missing Control Method Selection Error
Control method with PG feedback
was selected A1-02 = 1 or 3, but a
PG option board is not installed, or
is installed incorrectly.
Verify the control method in A1-02
and/or the installation of the PG option board
Manual link:
Aug 18, 2010 | Inverter Yaskawa F7 Drive
Teco AC displaying H5 error code... service mechanic looking for a hand
Try this link, as you didn't indicat what model you have. There are manuals in pdf form you can download. They will have a fault code listing if you can determine what model you have
http://www.tecowestinghouse.com/products/Drives/ga7200.html
Jul 03, 2010 | Inverter Yaskawa F7 Drive
Meaning of rudd furnace trouble codes
Error Codes
stuck open)
stuck closed)
increases
Dec 12, 2009 | Heating & Cooling
I have a fault code on a yaskawa varispeed f7 drive
Jun 21, 2009 | Inverter Yaskawa F7 Drive
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
