Brivis fan on cooler runs for a few seconds then stops
5 Suggested Answers
SOURCE: cpu fan starts then stops
I figured it out....... the cheap ass cpu fan went south
Posted on Jan 12, 2008
  • 54 Answers
SOURCE: the airconditioning fan runs for a few seconds then quits. The rear operates fine.
Sounds like your blower motor has quit if it is inop on all levels. If high speed works and the other speeds do not, then its probally the rheastat or resistor pack
Posted on May 05, 2009
SOURCE: brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: Our fan on our brivis evaporative cooler is not wo...
there is a fan insert with a part Number 17517 this insert sits on the shaft of the motor. my fan is working but not blowing so i went up on to my roof and found out that this particular insert is broken (due to a birds nest )
Posted on Jan 29, 2011
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
How to turn on the brivis buffalo 52
Refer the user manual given below to setup your Brivis Buffalo 52 and start operating it:
Brivis_Manual
May 28, 2012 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
Our fan on our brivis evaporative cooler is not working. The pump to fill it with water is working and the fuse is fine. what else could it be - the unit is on the roof and I can not get to it.
May 17, 2010 | Heating & Cooling
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
Where can I get a wiring diagram for an under-counter Beverage-Air cooler. The condenser runs then stops after a few seconds. Figuring a bad relay? The power runs but the condenser kicks off immediately...
If it's the condenser fan you are talking about you will not need a wiring diagram. The fan should be wired to the compressor and the thermostat. the thermostat is the relay to start the fans and compressor. I will continue to look for a wiring diagram. When the fan wears out they will stop causing the cooler to overheat. I think replacing the fan would be what you need. I believe that Beverage Air used the Copeland compressor with the condenser fan mounted on the one end of the the same slide in compressor. Check your voltage on the 2 wires going to the fan. When compressor is on the fan should also be running. I just have the feeling that condenser fan is defective.
Sea Breeze
Aug 19, 2009 | Refrigerators
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
