Question about Carrier Heating & Cooling
Need wire diagram for carrier ac/heat model xhd183d
  • 1,373 Answers
May find one on Google images, worth a look
Posted on Dec 14, 2016
  • 9 Answers
SOURCE: Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Posted on Dec 15, 2007
  • 69 Answers
SOURCE: wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Posted on Dec 21, 2008
  • 415 Answers
SOURCE: need a wiring diagram for capacitor on carrier ac
Here's your wiring diagram. :-)
Posted on Apr 02, 2010
  • 82 Answers
see page 2 here...the drawing section with H (hermetic compressor) F (fan) and C (common. -- http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/38en-1w.pdf
Posted on May 10, 2010
SOURCE: need wire diagram for 3207-121189
a/c compressar not warking supply coming
Posted on Mar 29, 2013
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
An air conditioning technician told me that my Carrier XCB183D (9 years old) needs to be replaced (not cooling sufficiently) but that model is no longer available. Is that true?
Thats very likely, they update and come up with more efficient units and discontinue the older models.
The compressor will lose effieciency over time.
Jul 28, 2011 | Carrier XHD183D Air Conditioner
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
Identify unit capacity.
The nameplate will provide a large amount of information, including the the manufacturer's name, model, serial, electrical requirements and the BTU rating or capacity that I believe you are looking for. Like the 120 volt sisters, the 240 volt unit should also have a nameplate. If unable to locate it on the chassis or frame of the unit in a similar location as the 120 volt, you'll have to look elsewhere. A www.google.com search on model number you provided (XHD183D) for this question indicates that it is a 17,900 BTU unit. If this is the correct model, case closed. If not, continue reading.
A good place to locate a nameplate if not plainly visible on the unit as it sits in the window would be on the chassis or frame behind the decorative grille. The grille is likely held in place by several clips and a screw or two. Shut off the AC and unplug it from the power source. Remove the filter as if to clean and carefully check for and remove screws and remove the grille.
I hope this helps!
Jun 07, 2010 | Carrier XHD183D Air Conditioner
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need inside cover for Carrier heater/ac wall unit
Hi, since these systems are specifically sold through Carrier and Carrier dealers, then you need to go directly through them for all parts. Please call them at the following number to order the parts or find a local dealer to order the parts needed.
Monday-Friday, 8am - 5pm Eastern
Phone: 1.800.227.7437 or 1.800.CARRIER
Let me know how this turns out.
Benjamin
Jul 23, 2009 | Carrier XHD183D Air Conditioner
Dec 13, 2007 | Carrier XHD183D Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
