I have admiral jsj12674 in the main board. One resistor is no meter reading.the big one resistor. What value the resistor. Pls. Help me. Tnx..
  • 4402 Answers
SOURCE: hitachi resistor value
Posted on Dec 05, 2007
  • 8617 Answers
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Posted on Mar 24, 2008
  • 132 Answers
SOURCE: TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
Posted on Aug 24, 2008
  • 905 Answers
SOURCE: Convergence Resistor Hitachi 50DX10B
rk46 should be a 1.8 1w
Posted on Oct 30, 2008
  • 8617 Answers
SOURCE: magnavox 60p8341a trying to get
R3231 is a 220 ohm 5% 2 1/2 Watt metal film resistor
Posted on Sep 12, 2011
Pls somebody here knows the exact value of the ff burned components resistor and diode of power suppy section of minami mtv-2122 FLTGN. Attached photo tnx...
Sorry I don't know but I just wanted to advise you to obtain a circuit diagram as resistors rarely burn themselves out and the fault is likely to be an overload caused by other components on that circuit.
Nov 18, 2017 | Televison & Video
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
Mar 12, 2012 | Televison & Video
Need power supply board for Admiral JSJ12674 TV
Free offer: Admiral TV 19" model JSJ12674 with remote control.
Excellent Working condition.
RCA Digital TV to analog converter.
You take in Milpitas, CA.
Please contact:
Jun 15, 2010 | Televison & Video
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
Need info
I made a couple videos about reading and testing resistors. Keep in mind, if you're reading a resistor while it's still in the circuit, it might not read the value that it says on the resistor because of the circuit it's in. While in circuit it can only read the value of the resistor or less. If it reads more ohms while in circuit, then the resistor is probably open. My meter reads OUCH when it's open and 0 when it's shorted.
Feb 26, 2009 | Toshiba 43H70 43" Rear Projection...
I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts:
Feb 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Jan 27, 2009 | Wahl 8685 Hair Trimmer
Televison & Video Logo
Top Televison & Video Experts
