Question about Invacare Health & Beauty
DOES MY INVACARE PRONTO M91 Power wheelchair have internal thread battery terminals or the nut & bolt type of terminal ? Bill Cadman Grants Pass, OR
  • 103 Answers
SOURCE: I have a inacare pronto m91 sure step. The SJ+
You have a remote, joystick, problem.
Posted on Nov 06, 2009
  • 409 Answers
SOURCE: The bolt threads are stripped on my auto battery.
If it is the bolt that is stripped you can buy a new bolt at any parts store, if the threads in the battery are stripped, well you can get one of those at the parts store as well. You can probably rethread the hole to a bigger size, or use a heli-coil thread insert, but I have never tried one of these on a battery and dont know how well it will work out.
Posted on Mar 14, 2010
jyackle5
  • 8197 Answers
SOURCE: i am in need of
You can get the manual on the link below for your chair.
NOTE: The following procedures refer to the Pronto. R2 and the Pronto. R2-250 Series
http://www.rentascooter.com/downloads/_manuals/invacare/Invacare%20Pronto%20R2%20Owner's%20Manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Aug 13, 2010
Testimonial: "such a quick response is very appreciated an directions to the correct web site. thank you very much for a job well done."
  • 692 Answers
SOURCE: my invacare pronto m51 wheelchair
Did you replace both batteries? How old is the chair? Sometimes the on-off keypad becomes worn and does not make contact with the on-off switch. When charging the joystick lights can light up but after unplugging they should remain on. When you plug in the charger look under the rear cover at the charger you should see 2 lights, one red and one yellow to indicate that you are charging the chair if you do not see both lights lit then the charger is bad or has a blown fuse. Only a Tech will be able to tell what is wrong. If Medicare purchased your chair then they will pay for most of repair costs. Contact your provider or a repair service company
Posted on Aug 17, 2010
larrymatthew
  • 318 Answers
SOURCE: I want know how to
I am confused by your description of the process you are using to remove a battery. If you can not charge the battery in place then there should only be three bolts to undue to remove it. There should be a rubber wedge near the bottom of the battery with a bolt going through the center that holds the battery down. This bolt needs to be removed and the block taken out to be able to lift the battey out. To remove the cables start with the negative one so that if you touch a metal part of the vehicle with the wrench it will not short to ground (put negative back on last for same reason) then positive side. It should be a cable side mount type battery with small bolt heads that actually undue a larger (approx 3/8") bolt that goes into the side terminals of the battery. If you have any further questions please reply to my solution.
Posted on Dec 01, 2010
Does my Invocare Pronto M91 power wheelchair have internal thread battery terminals or the nut & bolt type of terminals ? Bill Cadman Grants Pass, OR
Nut and through bolt terminals on group 22 batteries. The special Invacare fuse and terminals only work on this style battery.
Dec 14, 2016 | Health & Beauty
Does my Pronto m 91 require internal thread battery terminals or the nut & bolt type of terminal ? Bill Cadman Grants Pass, OR
surely if you open the hood and look at the cables you will see what kind of battery it has .
Dec 14, 2016 | Cars & Trucks
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
Jul 08, 2014 | Invacare Supply Group Invacare Pronto M91...
How to recharge but I get a flashing red light on transformer in battery box. this is a Invacare Pronto M91 Electric Wheelchair
The red light on the transformer/Charger means the charger is bad. Sometimes it can also be battery harness wiring. Most often it is the charger that needs replaced.
Jun 22, 2014 | Invacare Supply Group Invacare Pronto M91...
How do I get my pronto m91 out of charging mode?
The M91 has an onboard charger. When unplugging the charger power cord from the wall outlet does not stop the chair from being in the charge mode, The charger has to be unplugged from the wheelchair wiring harness or main control module under the plastic body parts. The on-board chargers fail like this sometimes.
Jun 06, 2014 | Invacare Supply Group Invacare Pronto M91...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
Batterys charged. I turn switch on. all the lights come on. Joy stick doesn't do anything. Pronto m91 (trulffes@asisna.com)
truffles e-mail me at lennieg2000@yahoo.com. I need to know if you are getting any flashing lights on your joystick and are you hearing the brakes click when you move the joystick. Thanks
Oct 18, 2010 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
67 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
