Question about Sewing Machines
* HDC 7, 2 HDC in the next, repeat from * around 6 times, slip stitch, chain 1, do not turn – 54 HDCs.
Singer 1036 1-step buttonhole foot. It will make 1 perfect buttonhole. When I try to make the next one it makes a short buttonhole, never moving forward enough to hit the lever.
Possibly your machine does not make repeat buttonholes and you need to set every time? Are you stitching all the way around before resetting.
Dec 17, 2016 | Singer Sewing Machines
When crocheting what does * HDC 7, 2 HDC in the next, repeat from * around 6
Make 7 half-double crochets, then 2 half-double crochets in the next stitch, then repeat.
Dec 14, 2016 | Sewing Machines
Meaning of these crochet instructions.ch 2, in first sc (1 sc, 1 hdc, 1, dc), * Will. I make my ch 2 where the parentheses begin or in the single crochet in my last row of a shell
Chain 2 then in the next SC (of the row below), make the combination stitch. So, if the previous row has a bunch of SC, you would make the stitches leading up to the Chain 2. Then Chain 2 and in the next SC, make the 1SC, 1 HDC, ! DC.
Dec 02, 2016 | Sewing Machines
How do we fix a repeating touch screen on a Janome 5700. The touch seems to be ok., but the display is not.
You might try recalibrating the screen. Short of that, could be a computer screen component is failing.
Nov 13, 2016 | Janome Sewing Machines
What does C4 mean in knitting
I believe it means a 4 stitch cable or a stitch made with 4 threads. I found this on a knitting website and it might help:
"A 4-stitch cable will be made with 4 stitches, a 6-stitch cable with 6 stitches and so on. Most of the time these sets of stitches are divided equally.
For the 4-stitch cable the first 2 stitches are slipped purlwise onto a cable needle or double pointed needle whichever you prefer. You will knit the next two stitches on your left needle, and then knit the two stitches from the cable needle. The knitting stitches are crossed over each other and you have created a nice little cable stitch."
Here is a YouTube video for the stitch: How to Knit The 4 Stitch Cable
Mar 05, 2015 | Sewing Machines
Can you please explain further what this knitting abbreviation means k3to7= knit 3 sts together w/o dropping them of the needle, yo, repeat 2 more times, knit 3 sts together once more, slip sts off the...
It looks like you would scoop up three stitches instead of one and then instead of transferring them over to the other needle you would yarn over and repeat that action twice more, then scoop up three stitches knit and count how many stitches you have if you do it right you have increased the row from 3 stitches to 7.
Try and see if it looks right. Bill in Oregon
Feb 05, 2015 | Sewing Machines
Skipping crochet stitches in pattern
Ok, so do what it says... put your next stitch in the 81st stitch of the previous row.
HDC=half double crochet.
Mar 14, 2013 | Sewing Machines
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
