Question about Miscellaneous
My parcell has not arrived - Miscellaneous
Why has my parcel not arrived? I waited all day yesterday I received an e mail saying it had been delivered
hi Lynda.
sorry but this is a fixya site and this has nothing to do with us.
you will need to get in touch with whom you are getting your parcel from.
Nov 21, 2017 | Computers & Internet
My delivery of my parcel, it still hasn,t arrived. It was suposed to come today
why do you ask this here?? fixya doesnt ship anything anyplace
Sep 28, 2017 | Computers & Internet
How can I find out if a parcel from UK really arrived in SA
parcel tracking
might be online these days or
go to the closest post office and fill out a
"find the parcel type form "
Apr 12, 2017 | Computers & Internet
I have an Acer aspire laptop 5552 with windows 7 but it no longer works, i didn't get a reboot disc with it can you tell me how I can reboot it
if your warentee is up on your laptop, you would have to purchase a new o/s or a recovery desk from the windows website, or even buy a new laptop all together. Otherwise for warentee you are required to mail back the laptop with a copy of the reciept. I would also purchase tracking on your parcel just to make sure that you know it arrives.
Jun 17, 2014 | Computers & Internet
What is the zip for leicester, wher postal code is le55pd
The postal code, or post code, is the UK's equivalent to the US system of zip codes.
If you put a house number and a post code on a parcel or letter, it will arrive just fine; post codes tend to cover under a maximum of about 75 houses.
Jun 09, 2011 | Computers & Internet
How is latitude related to air temperature
The temperature of the troposphere generally decreases as altitude increases. The rate at which the temperature decreases, dT / dz, is called the lapse rate. The reason for this decrease is as follows. When a parcel of air rises, it expands, because the pressure is lower at higher altitudes. As the air parcel expands, it pushes on the air around it, doing work; but generally it does not gain heat in exchange from its environment, because its thermal conductivity is low (such a process is called adiabatic). Since the parcel does work and gains no heat, it loses energy, and so its temperature decreases. (The reverse, of course, will be true for a sinking parcel of air.) [1]
Since the heat exchanged dQ is related to the entropy change dS by dQ=T dS, the equation governing the temperature as a function of height for a thoroughly mixed atmosphere is
9df09585dbe18cef06221a59290536de.png where S is the entropy. The rate at which temperature decreases with height under such conditions is called the adiabatic lapse rate.
For dry air, which is approximately an ideal gas, we can proceed further. The adiabatic equation for an ideal gas is [3]
beb483b44843aad0a6cddff7b1385c8a.png where γ is the heat capacity ratio (γ=7/5, for air). Combining with the equation for the pressure, one arrives at the dry adiabatic lapse rate,[4]
c4507116c9a4244af81e3aa8b865d863.png If the air contains water vapor, then cooling of the air can cause the water to condense, and the behavior is no longer that of an ideal gas. If the air is at the saturated vapor pressure, then the rate at which temperature drops with height is called the saturated adiabatic lapse rate. More generally, the actual rate at which the temperature drops with altitude is called the environmental lapse rate. In the troposphere, the average environmental lapse rate is a drop of about 6.5 °C for every 1 km (1000 meters) increase in height. [1]
The environmental lapse rate (the actual rate at which temperature drops with height, dT / dz) is not usually equal to the adiabatic lapse rate (or correspondingly, e52ae677de914e5cfddd35c399e2c57b.png). If the upper air is warmer than predicted by the adiabatic lapse rate (dS / dz > 0), then when a parcel of air rises and expands, it will arrive at the new height at a lower temperature than its surroundings. In this case, the air parcel is denser than its surroundings, so it sinks back to its original height, and the air is stable against being lifted. If, on the contrary, the upper air is cooler than predicted by the adiabatic lapse rate, then when the air parcel rises to its new height it will have a higher temperature and a lower density than its surroundings, and will continue to accelerate upward.[1][2]
Temperatures decrease at middle latitudes from an average of 15°C at sea level to about -55°C at the beginning of the tropopause. At the poles, the troposphere is thinner and the temperature only decreases to -45°C, while at the equator the temperature at the top of the troposphere can reach -75°C
Feb 26, 2010 | RTO Help! My Science Project Is Due...
Miscellaneous Logo
21 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
