Question about PfaFF Sewing Machines
Pfaff hobbylock 4870 upper knife will not engage.
When turning to off it engages but will not change. Turning the knob to the right seams not connected to anything. Is there a adjustment for this? I have also changed the blade position with no luck. Nancy
4 Suggested Answers
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
SOURCE: Pfaff hobbylock will not run
it's sounds like the machine needs to be serviced
Posted on May 29, 2012
  • 1564 Answers
SOURCE: Pfaff serger hobbylock 4870 converter stuck on on
Have you tried gently wigging the hand wheel while attempting the change?
Posted on Sep 08, 2012
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Jun 14, 2017 | PfaFF Sewing Machines
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
Aug 30, 2012 | Sewing Machines
I need a manual for a Pffaf Hobbylock 4870.
Jan 11, 2012 | Sewing Machines
Pfaff 1222 foot pedal
This indicates some sort of drive issue; your machine may have a belt that is worn or a bit stretched inside it connecting the flywheel to the engine.
But as a first check, does your machine have a bobbin winding clutch that you disenage by turning an inner knob on the flywheel? If yes, then just check that the clutch is fully engaged as this could also cause the drive loss.
Failing that, if your machine has not had a professionaly service in the past 2 years then probably worth taking it for one now and the mechanic can check out the drive components and adjust/replace.
Jan 04, 2012 | PfaFF Sewing Machines
I need a manual for a Pfaff Hobbylock Serger 4762, where can I find one
I can't find a manual for this model, however there is a general hobbylock book which would certainly be a good start.
You may find best source is to contact Pfaff locally and source it from them direct.
You could also try, I can't see this manual but if you go through similar model numbers manuals you may see one very similar. Overlockers/Sergers are very similar in many ways so once you've mastered one, the next one is pretty straight forward. Four tension knobs, 2 needles and 2 loopers is the norm - to get a three thread stitch you just don't thread one of the needles. Tension adjustments alter the stitch formation, and you should have a stitch length knob on the right side of the machine along with a flywheel and if it has it, differential feed (which controls the feed dogs so you can stretch, or compress the fabric as it goes under the foot).
There are some good general how to use a serger books in the marketplace too which should help. Threading up, many machines have a diagram inside the front flap, colour coded dots on the knobs, eyelets and loopers. And oiling points are often marked on this diagram too. But basically oil the two loopers where they slide/move on another metal part. Some good info here too
Hope this assists you a little.
Apr 18, 2011 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
I have a pfaff Hobbylock 4860 serger. I got it serviced about 6 months ago but never used it until about a month ago. Now it will not cut my fabric as I serge. What should I do?
If it won't cut then you need either a new upper knife or lower knife. One or both has gotten dull or nicked up. The place you got it serviced or any dealership should be able to order new knives for it.
Dec 10, 2008 | Sewing Machines
How do you get the blades to cut on a hobbylock 794 serger
It should just cut. Don't know too much about this machine as I'm new owner, but from what I can gather, either you need a new blade, or the upper knife is disengaged. The metal knob inside the threading area should be turned downwards, engaging the upper knife. The upper knife doesn't usually need replacing unless damaged, apparently. Hope this helps somewhat.
Dec 04, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
