Question about Legacy Car Audio & Video
What size of fuse does a American legacy series 2 1000watt amplifier take
  • 113 Answers
SOURCE: Installing Legacy LA690 Amplifier
the12volt.com
Posted on Aug 09, 2007
  • 883 Answers
SOURCE: what size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Posted on Dec 13, 2007
SOURCE: i have an american legacy series 2 1000watt apm
If the fuses were the problem then you would be replacing them all the time. Fuses are only good once - and are only in place to protect the circuitry from damaging overcurrent situations.
More likey, the problem is a thermal protection resulting from over-driving the amplifier. What impedance are the speakers you are running? Does the amplifier support that impedance? Typically, car audio runs 4-8 ohm impedance. Many amps have a switch to place the unit in the proper impedance mode.
Check your wiring. Do you have it wired correctly?
Posted on Apr 03, 2009
  • 3 Answers
SOURCE: I have an American Legacy Amplifier series II
usualy a 30 amp fuse because they can hold alot more power than a 20
Posted on Sep 30, 2009
kingbrizzle
  • 407 Answers
SOURCE: I need to know the size of external fuses for a
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Posted on Jul 11, 2010
Anyone can help me please?
Can't really find anything about them but maybe if you contact Legacy and beg a little they might have a circuit diagram hiding away somewhere. Here:Legacy
Jan 29, 2012 | Legacy - American II: 2 Channel 600W...
CAN THE AMERICAN LEGACY SERIES 2 LA490 AMP HANDLE A 2 COILS 12'' KICKER SUBWOOFER??
yes, should be fine in series or parallel. it will run hotter under lower ohms but crank out more volume!
Jan 28, 2011 | Legacy Audio American Legacy II LA490 Car...
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
What size fuse do i need for amp
600 watts = 12x
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Optimum sound performance needed
1) legacy products are highly overrated and i have never seen one put out the power it claims
2) if you are running the amp bridged, you need to match the impedance of the speakers to the amps highest output impedance, otherwise your system will not sound all that great...
what size fuse or fuses does your amp use? what size wire did you install with (power and ground)? did you connect direct to battery or did you connect to a fuse block or similar? did you use a stiffening capacitor? does it sound like it is clipping when you turn it up or is it just distorted? what kind of box are you using for the speakers (ported, vented, sealed, bandpass)?
if you give me the model number of your speakers and your amplifier i can probably help you more, but with the information you have provided, this is all i can offer..
hope it helps,
trin
Nov 11, 2007 | Legacy - American II: 2 Channel 2000W...
Car Audio & Video Logo
89 people viewed this question
Top Legacy Car Audio & Video Experts
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
