Question about Saws
How do i change blade on ryobi 210mm compound saw cms1421
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
Editor925
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
  • 13 Answers
SOURCE: loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Posted on Jun 05, 2009
  • 288 Answers
SOURCE: Need to calibrate my dw708 sliding compound miter
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Posted on Dec 23, 2009
How do I change blades on ozito 210mm compound saw
hopefully this manual helps.
There are pictures and instructions on changing the blade, starting on page 15.
http://cdn0.blocksassets.com/assets/ozito/ozito-product-manuals/VFIW5zKsTiAxHGZ/CMS-210.pdf
Oct 27, 2017 | Saws
Saw do not lift when turned over
Is this the saw you are talking about? A compound mitre saw?
TFO 250 Ryobi
I'm assuming you cannot lift the blade up by the handle without the whole saw coming with it. That usually means that the saw is locking into place for transportation purposes. Look at the pictures below and see if the lock pin in engaged.
Apr 19, 2015 | Ryobi Saws
I need a replacement fence for a Ryobi CSS1000 compound mitre saw.
Have you checked on Ryobi? You might want to check Kreg fence. What type of blade are you using right now? I have a saw and I got online supplier for blades , I purchase on sawblade.com , happy with them. Good luck.
Jan 08, 2014 | Saws
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Changing the saw blade on a Ryobi Mitre saw
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
How do I remove the guard?
Lift the guard up and you will see a nut holding the blade. You should not have to remove guard to change blade. Make sure unit is unplugged before working on it.
Dec 24, 2008 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
134 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
