Question about Konica Minolta Office Equipment & Supplies
Konika 164 solve error 5102 - Konica Minolta Office Equipment & Supplies
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Code is due to failure of main motor proper rotation.
This could be due to overloading .
can check Drum unit about free movement
Check Fuser unit abt free movement.
Check main motor gear shaft & surrounding Gears if damage and worn out...
Posted on Dec 25, 2016
HOW do i solve error code 3451 in konika monolta bizhub 165
switch on the machine pressing Stop switch and wait for 5 second then leave the stop switch. It happens due to low voltage. use stabilizer in your machine. If it does not solve the problem then check the heater bush of fuser unit which has been damaged.
Dec 16, 2014 | Konica Minolta bizhub Office Equipment &...
Error 5102 installing panda endpoint agent
use MS ESSENTIALS or clamwin av it is free antivirus software
Jun 24, 2014 | Panda Antivirus Pro 2009 - 3 User for PC
Bizhub 164 error code CC153
Have a tech come and re-flash the firmware, and check the NVRAM. Firmware is only available fro secure Konica Minolta Web site they like to keep they software secure. You mite also have a bad control board. Or the memory on the board, a Tech is required.
May 08, 2014 | Konica Minolta bizhub Office Equipment &...
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
C-5102 error in C353
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Feb 08, 2014 | Konica Minolta Bizhub C353 Copier
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
Apr 17, 2012 | Konica Minolta Office Equipment & Supplies
Konika minolta bizhub 164 how to enter into service mode
Jan 05, 2012 | Minolta Office Equipment & Supplies
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
