Question about Water Water Heaters
I have an AO Smith Hot Water tank and the status light is flashing - the code is low flame signal..... what does that mean
    Top Expert:
  • Water Master
  • 51,591 Answers
Google it and read any thing you find there , or call a plumber
Posted on Dec 14, 2016
Takagi t-k3 runs hot on low to med flow on high turns cold & flame shuts off
OMG 95 PSI is too high a pressure for a tankless! What was the W.C. in inches on the manometer?
Also on a T-K3 12 isn't a Code but a partial Code. You need an R/C to make this easier as counting led flashes produces wrong codes.
you'll have to find the correct code it's throwing not a partial.
And put a Pressure Reducer on this to below 60 PSI. 95 PSI is only impressive when it blows the tubing out after a few years.
Call Takagi in California not A.O. Smith in TN and they'll help someone fix this
Sep 20, 2014 | RTO Takagi T-K3 Flash Gas Tankless Water...
AO Smith GPS 75 200 not working
Copy following link for troubleshoot service manuals by type of gas control valve, including instructions for replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.hotwater.com/lit/training/320988-000.pdf
Perform the required maintenance, and catch unit up to date, and replace gas control,,, might be best to call plumber.
The intellivent gas control valve is removed completely from tank, so tank must be drained.
May 01, 2013 | Water Heaters
Pr sw failed to close
Troubleshoot by type of gas control valve
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
Water Heaters Logo
57 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
