Question about Boating
How does the Choke work on a 175V6 Sports Jet Motor.When I push the key in nothing happens
  • Boating Master
  • 20,454 Answers
The choke is electronically operated. When you push the key in, it operates the choke. You should hear a 'click'.
Your manual is here
175V6 Sports Jet Google Search
Posted on Dec 14, 2016
Mirolin jaccuzzi tubs
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Jan 28, 2014 | Home
Hi there i have a 2004 Yamaha YZF 250 that will run on choke then push the choke in as soon as u give it throttle its bogs an back fires then dies or u can build the revs it runs jst bout thanks
Would almost certainly be blocked pilot jet and pilot circuit a classic symptom of this is running only with choke on
buy new pilot jet an compress air clean the hole the pilot jet screws into
regards Jamie
Aug 28, 2011 | 2004 Yamaha YZ 250 F
My poulon lawn mower will start witht he choke fully on. Once it is running and the choke automatically starts to close, it get about 2/3 closed and the engine dies. I have cleaned the float bowl and...
Sounds like the main jet in the carb is clogged. It will operate on the choke circuit but not on the main circuit. The main jet needs to be cleaned.
Jul 20, 2017 | Poulan "" Push Mower
Have 1200 xlt yamaha jet ski is their an aftermarket fuel pump to help on starting cheers all dave
This motor has 2 accelerator pumps on the carbs, pull the choke, turn it over for about 5 seconds then pull the throttle trigger 2-3 times and it should start right up, then push in the choke.
Oct 09, 2010 | Computers & Internet
Pressure washer will run with choke on push choke in motor shuts off
The main jet is restricted. Suggest you remove carb and clean/rebuild it.
Jul 15, 2010 | Karcher 2500 PSI Pressure Washer
1995 Yamaha XV 250 Virago Is there a need to adjust the choke (start) cable? If so, how is it adjusted. I think I'm having a problem with my choke and was planning to replace the cable and starter...
The problems with a plunger style choke happen when the rubber on the bottom becomes deformed and does not seal or the spring does not push the plunger down hard enough, or the cap breaks so the plunger is not pushed down hard enough. If you put your finger over the hole and the bike runs properly your bike is running on choke. You have to block the hole deep inside the carb to shut off the choke. I assume the original problem was that the bike would not idle .If this is the case, take the carb apart remove the slow jet and clean the jet and the carb body out so fuel will flow at idle. This should fix your no idle problem.
Jun 26, 2010 | 2002 Yamaha Xv 250 Virago S
Must push choke in periodically to keep it running. it's a remote control, and you choke it by pushing in the key. mod#; bj35vl3sie. 2 stroke.
Adjust your idle mixture screw. If that doesnt work then run the engine at high rpm's and push the choke in until it is about to die and let off. This will create a vaccuum in the carb and possibly **** out any particles in your jets. If that doesnt work then I would rebuild the carbs.
Sep 29, 2009 | Light Outboard Motor Boat Bass Fishing...
96 dr200 sittig up for 2 yrs. starving for fuel
Get some carb cleaner. Remove and clean the Nozzle, choke and main jet. Remove the pilot jet and air jet but count the number of turns to remove each one and put them back the same number of turns. Don't mess with the needle or clip or the pilot screw and plug at this time. Clean the carb thoroughly. Don't get carb cleaner on the diaphragm. If able, submerge the carb in cleaner overnight.
Let me know what happens by posting a comment.
Jun 27, 2009 | 2001 Suzuki DR 200 SE
Boating Logo
363 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
