Question about KitchenAid Washing Machines
Kitchenaid washer doesn't spin - KitchenAid Washing Machines
  • 13,433 Answers
Here is some general advice on washing machine not spinning, good luck:
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • Ifthe motor is running, your washer probably has a frozen pump pulley ora broken pump belt. To check the pulley, remove the pump from thewasher and try to rotate the pulley manually. If it doesn't turnfreely--if it's frozen or stiff--replace it. If the pump belt is brokenor looks quite worn, replace it--but be sure to check the pump pulleybefore you change the belt.
  • If the motor isn'trunning, the lid switch may be defective. If so, the washing machinecan't spin and may not function at all. The switch is inside thewashing machine main housing near the door frame. Often you have toraise or open the top or front of the washing machine to get to theswitch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • Thelid switch may be defective. If it is, the washing machine doesn'tspin. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
  • The motor coupler may be broken. ManyWhirlpool®-manufactured washers use a small, relatively inexpensivemotor coupling. It's plastic and rubber and is mounted to the shaft ofthe motor on one side, and to the transmission on the other. Over time,the coupler wears out and fails. You may need to replace it.
  • Abelt may be broken. Many washing machines have one or two belts. If abelt is broken or badly worn, you need to replace it with a genuinebelt from the manufacturer. (Some washing machine belts are designedwith special characteristics not found in automotive belts.)
  • Theclutch may be worn. If your washer is a GE, it may use a clutch to comeup to the proper spin speed. As the clutch wears out, it may preventthe unit from spinning well or at all. If the clutch is worn, you needto replace it. For this job, you probably want to hire a qualifiedappliance repair technician.
  • The drive motor may bedefective. Many washer brands use a reversing motor. For agitation themotor runs in one direction, for spinning and draining, the other. It'spossible for a motor to burn out in one direction and continue tooperate in the other. If this happens, you need to replace the entiremotor.
  • The transmission may not be shifting properly.Older washers produced by Whirlpool® have a transmission with anelectro-mechanical shifter. If the shifter becomes even partiallydefective, the unit may drain the water but not spin. This is a complexsystem, if your washer has a shifter problem, you may want to hire aqualified appliance repair technician to repair it.
  • Thespin bearing or basket drive may be worn or seized. These componentsallow the inner tub to spin freely inside the outer tub. When this isthe problem, you usually hear a loud sound during the spin cycle. Calla qualified appliance repair technician.
It spins only with the lid closed Forsafety, washing machines are made so that they spin only with the lidclosed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 20, 2009
Spin cycle doesn't spin
what kind of washer is it top load or front load and brand.?
May 26, 2012 | KitchenAid KAWS850L Top Load Washer
Kitchenaid kawe450vwho Clothes Washer
try cleaning the screen on the inside that is used to filter anything from getting into the pump propeller. if that doesn't work it could be a burnt solnoid valve
Nov 10, 2011 | Washing Machines
Describe your kitchenaid clothes washer KAWE450VWHO Problem will not spin or drain water.
If it makes any noise when it SHOULD be draining and spinning, it's most likely your motor coupler. It couples the motor to the transmission and takes the place of a belt. If the machine it completely silent and just stops when it gets to the rinse/spin cycle, then it's probably the lid switch. Hope this helps.
May 25, 2010 | KitchenAid KAWS750L Top Load Washer
Kitchenaid washing machine not spinning
WHEN YOUR WASHING THE LID MUST BE SHUT BEFORE IT WILL GO INTO THE SPIN CYCLE. UNDER THE LID YOU WILL SEE A PROBE THE PUSHES THE SWITCH DOWN WHEN THE LID IS SHUT. THESE SWITCHES WEAR OUT , ONE THING TO TRY WHEN THE WASHER TRIES TO GO ONTO SPIN TAKE A NON MATALIC ITEM AND PUSH THE SWITCH DOWN AND SEE IF THE WASHER GOES INTO THE SPIN CYCLE, IF IT DOES THE SWITCH IS NOT BEING PUSHED DOWN FAR ENOUGH TO MAKE THE SWITCH WORK
THIS IS VERY COMMON ON ALL WASHERS
Aug 12, 2009 | KitchenAid Washing Machines
Kitchenaid kawe577bwh1 front load washer will not spin
Sounds like the timer might be defective. Try turning the timer manually to see if it goes into spin cycle. If it does then thats what it is. Hoped this helped if not let us know thankyou!
Mar 16, 2009 | KitchenAid KAWS850L Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
KitchenAid KAWS777E Washer will not spin
We are having the same problem. Try the lid switch. It is located just under the oval hole in the rim of the washer. There is a plactic pointer on the lid that pushes the lid switch down so the basket can spin. It is a safety thing. The plastic lid switch costs around $43 and is really not a problem to put in. Good luck!
Jun 22, 2008 | KitchenAid KAWS850LE Top Load Washer
Kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Jun 08, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Kitchenaid top load washer will not spin
ck wiring to motor for loose connections at motor plug wiggle connector to see if motor will start
May 10, 2008 | KitchenAid KAWS750L Top Load Washer
Washing Machines Logo
82 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
