Question about Alpine Car Audio & Video
Installed a used but tested good deck in my truck, Alpine CDE133BT and I have no sound from wired speakers but my amp and sub are working?
  • Alpine Master
  • 20,350 Answers
The installation, instructions and wiring diagram are here. Buying used is full of dangers. I would want to see it working before buying.
Alpine CDE133BT Google Search
Posted on Dec 14, 2016
  • 4 more comments
  • Jason Inskeep
    Jason Inskeep Dec 14, 2016
    I bought new just putting deck in different truck.
  • Andrew Taylor
    Andrew Taylor Dec 14, 2016
    Oh OK, check wiring and earths.
  • Jason Inskeep
    Wiring all correct, yellow to constant 12v power, red to switched power, blue w white stripe to amp, double ground chassis and amp ground through black and all speaker wires solids to positive stripped to ground. Speakers pop when deck turns on but no sound from speakers wired to head unit. Subwoofer working through amp though? Has yellow allumination wire that is n/a in old truck and a solid blue for power antenna also n/a in this application.
  • Andrew Taylor
    Page 35. Looks like wiring not quite right.
    http://www.google.ca/url?sa=t&rct=j&q=&e...
  • Andrew Taylor
    Yellow to Battery, Red to ignition, Blue and White remote turn on, blue to antennae, speakers have polarity.
  • Professor_V
    Professor_V Dec 24, 2016
    THERE ARE MANY APROACHES TO TROUBLESHOOTING THIS TYPE OF PROBLEM, BUT YOU MIGHT SIMPLIFY IT SOME BY SIMPLY USING A KNOW GOOD SPEAKER ON A COUPLE OF FEET OF WIRE AND JUST CONNECT IT STRAIGHT TO THE BACK OF THE UNITS WIRING HARNESS CHECKING THE OUTPUT OF EACH OF THE 4 OUTPUTS. THIS WAY YOU FIRST DETERMINE THAT THERE IS NO PROBLEM WITH THE PLAYER. THEN MOVE ON TO CHECKING THE WIRING AND THE SPEAKERS. IF YOU HAVE NO OUTPUT FROM THE PLAYER USING THE TEST SPEAKER, THEN SOMEONE HAD A WIRING OR SPEAKER FAULT IN THE PAST AND BURNED UP THE OUTPUT IC WITHIN THE PLAYER. MOST TIMES THIS HAPPENS, IT DOES NOT EFFECT THE RCA LOW-LEVEL OUTPUTS. ONE OTHER CAUTION IS TO MAKE SURE THAT THERE IS NO OPTION IN ANY OF THE SOUND MENUS TO ACTUALLY TURN OFF THE SPEAKER LEVEL OUTPUTS. WHILE RARE, SOME DECKS ACTUALLY HAVE THIS OPTION. OK. HOPE THIS HELPS......V
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
My speakers do not work but my subs do.
Good day sir, hi, there reason why speakers don't work could either be the folowing:
  1. you speaker voice coil is burnt, to test, you need to get the door speakers out and locate the terminals, prepare a 1.5 double AA battery, use this to test you speaker. connect a wire from the negative of the battery to the negative of the speaker, and the positive battery to the positive terminal of the speaker with a series of gentle taps, you should hear clicking sound. if not replace the speaker.
a9b085b.gif Do it on the other door speaker.
2. check your speaker line from the amplifier to the door speaker.
3. check your power amplifier for loose and improper connection.
4. check your power amplifier itself. Thats it.
Its a little work, visit your local electronic repair shop if your speaker still won't work.
Oct 08, 2009 | Car Audio & Video
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
Alpine amp wont turn on..
your power wire is sufficating yor amp probably
Jul 29, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Can't get my amplifier to work.
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
May 21, 2009 | Alpine MRP-M450 Car Audio Amplifier
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
658 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
