Iwas changing day clock on myx5 e53 pressed wrong side of the button which says bc light wont go off help
2 Suggested Answers
  • 5520 Answers
SOURCE: do i have an immobiliser problem?
Take a close look at those two lights. If one is a "check engine" light the car should be scanned. Autozone, Advance, and Oreilys do it free.
Some cars have switches on brake pedal levers or clutch levers which must be coordinated or timed to INTERLOCK with the starter. Also gearshift must be aligned similarily, such that all switches must be lined up for starter to work.
If lower switches are knocked out of position by feet, then it can cause starting problems.
Check your Battery voltage. Some antitheft are very sensitive to low voltage and the immobilizer will kick in.
Posted on Aug 22, 2012
How to set clock in radio on a 2014 Jeep Patriot
Clock Setting Procedure 1. Press and hold the TIME button until the hours blink. 2. Adjust the hours by turning the right side TUNE/ SCROLL control knob. 3. After adjusting the hours, press the right side TUNE/ SCROLL control knob to set the minutes. The minutes will begin to blink. 4. Adjust the minutes using the right side TUNE/ SCROLL control knob. Press the TUNE/SCROLL control knob to save the time change. 5. To exit, press any button/knob or wait five seconds http://www.chryslercommercialvehicles.com/jeep/download/pdf/manuals/2014-Patriot-OM-1st.pdf page 240
Mar 12, 2015 | 2014 Jeep Patriot
After power cut need to reset vcr clock on philips vr750 but have lost the manual
Hi
To set the clock:
Manual Clock Setting
1Press the VCR button, then press the MENU button.
2 Press the PLAY [UP]or STOP [DOWN] button to select INITIAL
SET UP, then press the FF /OK button.
3Press the PLAY [UP] or STOP [DOWN] button to select CLOCK,
then press the FF
/OK button
4Press the PLAY [UP] or STOP {DOWN] button repeatedly to set
the TIME. Every time you press the PLAY [UP] or STOP [DOWN] button,
the time changes in one-minute increments. If you press and hold
the PLAY {UP] or STOP [DOWN]9 button, the time changes in 30-minute
increments
5Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the DATE (month and day). Every time you press the PLAY
[UP] or STOP [DOWN] button, the day changes in one-day increments. If
you press and hold the PLAY [UP] or STOP [DOWN] button, the day
changes in 15-day increments.
When the month and day are correct, press the FF /OK
button
6Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the YEAR. When the year is correct, press the FF /OK
button. The day of the week will appear automatically
7Press the FF /OK button once again to skip "AUTO
CLOCK" and go to "D.S.T." (Daylight Savings Time).
Press the PLAY [UP] or STOP [DOWN] button to set D.S.T. to ON
or OFF. If AUTO CLOCK is OFF, you may set D.S.T. to ON or
OFF only
8Press the EXIT/STATUS button
Jul 13, 2011 | Philips Televison & Video
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
How do you reset the service engine light on a 2006 525i
In 2006 BMW developed what they Condition Based Service (CBS), this means even when you change the oil and filter, the only way to reset the service indicator is to take it to the dealer, to be hooked up to thier computer. I have the same problem, I am waiting for some aftermaket code breaker to be developed to fix this problem. Hope this helps, let me know.
Aug 09, 2010 | 2006 BMW 5 Series
How do you reset the Service light on 2006 BMW 325 xi, it stated service was due for brake fluid flush, we did that but the service indicator is still on
Hi , to reset the service light you will need to insert the key and turn the ignition lights on but do not start the engine. you will see a push button on the lower left side of the instrument panel press and hold this until you have a triangle appear which then turns to the brake warning symbol , release the push button then press and hold the bc button in the indicator arm until reset appears , release and again press and hold the bc button until you have a moving clock symbol appear , release the bc button and wait for the display to change , once this has reset turn off the ignition and the service symbol should have reset . you may want to print these instructions before resetting , regards Mark.
Oct 19, 2009 | 2006 BMW 3 Series 325xi
Need to change the date and time
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press "Play/Stop" to exit
Setting the Clock at any time.
1 Press and hold "Clock" until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down
"Memo/Repeat" or "ANNC/SKIP" until the
correct day is announced. Then
release the button.
3 Press and release "Clock". The current
hour setting is announced.
4 To change the hour setting, hold down
"Memo/Repeat"or "ANNC/SKIP" until the
correct hour is announced. Then
release the button.
5 Press and release "CLOCK". The current
minutes setting is announced.
6 To change the minutes setting, hold
down "Memo/Repeat" or "ANNC/SKIP" until the
correct minutes setting is announced.
Then release the button.
7 Press and release "CLOCK". The new day
and time are announced.
To check the clock, press and release
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Digital settings
Buttons are: A or Adjust (10 o’clock position), B or Time Memo (2 o’clock), C or Mode (8 o’clock), D or Receive (4 o’clock) and L or Light (6 o’clock)
To manually change time, date, year, month and day, hold A until beep and city code appears; press A again until 12H/24H flashes; press C to cycle through options as hour, minutes, year, month, and day flash; use B or D to change flashing option.
Aug 03, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
46 people viewed this question
 Grubhead
Grubhead
