Question about Frigidaire Kitchen Ranges
I was cleaning my Frigidaire oven and it started beeping and shows a f3 how can I fix it my door is locked
  • Frigidaire Master
  • 14,793 Answers
Flip the breaker, count to 10 and flip back.
Posted on Dec 14, 2016
Master_Tech
  • 770 Answers
SOURCE: tappan tgf355 oven door won't unlock and has code f3
open the back and manually spin the motor for the latch arm it may need to be replaced
Posted on Jan 25, 2008
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
  • 38 Answers
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Posted on Mar 04, 2009
SOURCE: Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Posted on Jan 27, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
Self-clean feature
hi .thanks for the question. f 3 on Frigidaire stoves, mean an open oven sensor. located in the oven top left corner, looks like a pen . replace the sensor. thanks the appliance doc
Oct 05, 2008 | Frigidaire FGF355FS Kitchen Range
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Frigidaire Electric oven model # GLEB27S7C
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
Jul 24, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
