Question about Sunbeam Food Mixers
Sunbeam heritage 2349 beaters fall out. howto repair?
  • Sunbeam Master
  • 20,292 Answers
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Motor head will not tilt back
Push down slightly on the head and then the button will go in further and the top will release. ((this answer after I just bought it home and was about to take it back to the store!!))
Oct 11, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
The beaters won't go around. The motor is running
I can't solve this problem, but mine just died doing the very same thing. Motor is running, the revolving base is turning, and the beaters are just sitting there. Ruined an entire batch of divinity!
Aug 30, 2009 | Sunbeam Heritage 2346 Stand Mixer
I did not receive a manual with my Mix Master model# 2349
If you go to www.apwagner.com you will get the story on Sunbeam and perhaps you may be able to get a manual. Please rate this answer,thanks.
Apr 11, 2009 | Sunbeam Heritage 2346 Stand Mixer
2349 Stand Mixer - Beaters now hit each other
The beaters can be retimed but, you have to open the mixer. There are 2 gears visible inside the head. Look closely for arrows or dots on the gears. These are the timing marks. Like marks should be placed exactly opposite each other on the work gear. (The spiral shaped gear) Look at the notches where you put the beaters. One will be lined up straight, the other will be at 45 degrees. While you have it opened, you might want to regrease it. Remove the old grease with a stick or small narrow screwdriver. Put vaseline or equivalent in the gear area. Only fill it about half way. If you over fill it, it will leak out when you get it hot from long or heavy use.
Jan 02, 2009 | Sunbeam Heritage 2346 Stand Mixer
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Nov 19, 2007 | Sunbeam 200 Watts 2484 Hand Mixer
Food Mixers Logo
136 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
