How to install cartridge guide on Model 80 DL
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 5430 dl doesn't print magenta
Please check your magenta cartridge if they are properly installed.
Make sure that your magenta cartridge are not empty.
Make sure that you are using the original konika minolta cartridge and not just a refill one or replacement one.
Aug 20, 2009 | Konica Minolta magicolor 5440 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Abit sg-80 1.0 bios driver
go web site dl bios make floppy show su on site how to do it or maby flash tool tanks nick
Oct 10, 2008 | Abit SG-80 Motherboard
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
BJC-80 - Wont' print
Look on eBay for printhead or cartridge cleaning solution. The cartridge is clogged with dried ink. Take an empty ink tank, and drip cleaning solution onto the sponge, filling the cartridge part way. Install the cleaning cartridge in the printer, and leave it over night. Run cleaning cycle the next day, and print with the same cartridge. It should start printing. Install new ink cartridge.
With the BJCs, if the cartridge is defective electrically, the printer will have an error and usually 3 beeps, it will not try to print.
Apr 23, 2008 | Canon BJC 80 InkJet Printer
27 people viewed this question
