Question about Fossil Watches
Size watch battery model BQ8776 fossil blue men's watch take?
    LISA BOO Dec 14, 2016
    I already have the back off but didn't know if was right one. When I got the watch it didn't work but had a engeizer 373 battery in it. Will that one work?
  • Andrew Taylor
    Andrew Taylor Dec 14, 2016
    Yes it will, it is a watch battery ??
    And you can get them in a pharmacy or mail order.
  • Fossil Master
  • 18,321 Answers
Just take it into a jeweller. They will do it while you wait, you won't have to buy 10, you won't have to buy the tools to remove the back, they have all the batteries in stock and will only charge you $6.
Posted on Dec 14, 2016
  • 3 Answers
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
  • 2334 Answers
SOURCE: i cant work my watch
Rate me, please
Posted on Jul 31, 2009
  • 103 Answers
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Posted on Aug 04, 2010
  • 831 Answers
SOURCE: unable to replace the back
Thank you for contacting FixYa.
This can be tricky. You may need to take to a store that has a watch press for replacing backs. Square watches are particularly tricky. I hope you were pushing the back on by pressing on sides of watch and not center as this may have warped it to not fit.
Best bet is a local repair.
Posted on Sep 24, 2010
  • 248 Answers
SOURCE: need battery size for blue
SR920 that is the size of the battery of your watch
Posted on Jul 11, 2011
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
At size is the battery in a mens fossil blue watch
take to Walmart and have them put in a new one .
Feb 15, 2015 | Fossil Watch
Hands on watch do not move but the seconds digital part still works. It is a fossil watch JR 8623.
your watch has two batteries you have to change the small one that power up the hands. the size of that battery is sr621. i hope i had been helped you.
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 12, 2011 | Fossil Blue watch #AM3574 Watch for Men
Dec 08, 2008 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
70 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
