I have a TND80 and while driving down the road the screen starts flashing off and on and finally goes off even though it is plugged into 12 I bought a new cord but still doing same thing
    Top Expert:
  • Computers & ... Master
  • 26,652 Answers
What make of laptop is this and please repost with more information;- OS would help.
Posted on Dec 14, 2016
4 Suggested Answers
  • 230 Answers
SOURCE: laptop will not turn on even though LED flashes
Remove the battery and the power cord, wait 5 minutes and put the power cord in and try and start it. If it starts shutdown the machine and try the same test this time put the battery in aswell. If the machine starts fine you will be ok, if it doesn't start with the battery in then you may need to replace the battery.
Posted on Jun 09, 2009
SOURCE: Touchsmart tx2z Screen Flickers and Freezes
it seems the touch part is off center because when i touch the screen it reacts one finger over
Posted on Aug 28, 2010
  • 2567 Answers
SOURCE: Even though it's plugged in, it acts like there is
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 18, 2010
Radio stopped receiving all of a sudden while driving down the road. When I removed the cover it smelled as though a component had burned up
If you were talking on it prior to it going south, you may have burned out the transmit final output transistor (Final). If the Finals shorts out, the receive goes way down.
Feb 16, 2014 | Radio Communications
1997 Dodge B2500 3.9L Cuts off
You mean coils for plugs?What is RPM how high?A Fuel filter is new.next is a crankshaft sensor.
Mar 15, 2017 | Cars & Trucks
99 dodge ram sputters and quits
check the wiring to the crank/cam position sensors or replace as required
Oct 09, 2017 | 1999 Dodge Ram
99 dodge ram 1500 sputters and quits
i would check three parts , i have seen a weak ignition coil make this happen, change fuel filter and last possibly either fuel pump or fuel pump regulator
Jan 12, 2013 | Cars & Trucks
I bought the inspiron 1545 last year and it was stolen from my apartment before i could hardly use it. after a year and a half i finally got it back without the charger. it hasnt been used since it was...
Remove the main battery and try to power up, if no result you probably have a motherboard issues, since it was stolen a professional check out would be the best option to see if it can be fixed.
May 10, 2012 | Dell Computers & Internet
I installed Dell Vostro 1000 System BIOS, v.2.6.1, A04 on myDell Vostro 1000. When it was finished the screen went black and it won't start. Now what? is the computer ruined?
Yep I did the same. Finally recovered using the link shown below.
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button
WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
Good luck Dean/Steve
Mar 11, 2011 | Computers & Internet
I am using a MS-6309 N1996 Ver 1 motherboard...how do I get into BIOS? I changed my hard-drive and now the screen eventually goes black at power up and a cursor flashes. I tried the 6 floppy discs initial...
Hello, you usually press 'delete' or maybe the tab key on power-up. Try and read the message that will flash up on the screen, usually momentarily, just before it starts to boot. Instead of powering down then back on, press your 'restart' button then you might see the messages that you may have missed if your monitor was still warming up. Regards, nicam49
Jan 22, 2011 | Intel Motherboard
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
