Question about Mintek Televison & Video
Mintek MODEL DVA 8700 - Mintek Televison & Video
2 Suggested Answers
SOURCE: disk not recognized...loads, but doesn't
I have a mintek DVA 8700 in our camper. The flat screen television shows it attempting to load the DVD on the p[roper screen, but after about 2 to 3 minutes it reads, "No Disk" I have tried 5 different disks with all the same results. It just started doing it. We had been using it for the last couple of years.
Posted on Jun 10, 2011
Remote control does not work
Good evening.
It is irritating when the remote doesn't work or is lost. You can download a remote in your phone and use the phone as a remote.
Before that check the batteries. It has been known to happen that a new battery is needed. Try that first before you try to get one from the internet it buy one in a shop.
kolbrun
Mar 09, 2016 | Mintek DVA-8700 System
Rear speakers do not work , also in set up menu they are grayed out.
hi there
when playing radio, the rear speakers do work because you have configured that. in your dvd player however, you may not have configured it yet.
Correctly insert the jacks at the back of the dvd player and at the same time, check the menu of your dvd player and check the audio settings. Under the audio settings of your dvd player menu, select the 5.1 or 6.1 audio profile.
hope this helps.
Feb 05, 2008 | Mintek DVA-8700 System
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
PAL, NTSC
Pls tell us which tv set u have..
Dec 08, 2007 | Mintek DVA-8700 System
I hit a wrong button in settings, and now the dvd player is gray, and looping so fast I can't go back and change what I pressed. Is there a DVD reset settings button anywhere?
i was doing a setup when i cleaked the swr? butten thats the dvd player stoped working it still plays cd but dvd i hear sound but no picture
Dec 24, 2009 | Mintek DVA-8700 System
I need remote code for Mintek LCD model 260
Use toshiba code 0156 that should turn on the mintek tv on
Jan 01, 2009 | Mintek DTV-263 26 in. LCD Television
Disk not recognized...loads, but doesn't succeed in playing disk, displaying "no disc" and stops disc spinning. What do I need to do to get the Mintek DVA 8700 to recognize discs. I've opened it to see if...
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 17, 2008 | Televison & Video
Help! I live in CANADA and accidentally clicked the PAL switch on with my remote control the home theater system model DVA - 8700 set-up and now I can here the sound but I can't see anything to find my way...
Pls try doing a reset by unplugging the unit from the mains for a couple of hours (preferably overnight).
Alternately, you can try hooking it up to a video monitor (capable of RCA/Composite or S-video), a movie camera (switch to external video source), or another TV that is PAL/NTSC capable while configuring it back to NTSC settings.
Additionally, you can try simply pressing the NTSC/PAL button with a few seconds interval while playing a known good NTSC disc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Televison & Video
Sound problem
no its not a problem..just that your radio is set to some surround preset and the other components are not..Probably the TV, DVD etc are set to 2 channel
Mar 04, 2008 | Audio Players & Recorders
PAL, NTSC
Can you somehow press on "DEFAULT SETTINGS"? Do you have manual for your TV? Which model you have?
Sep 28, 2007 | Mintek DVA-8700 System
Televison & Video Logo
35 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
