Question about Car Audio & Video
Manual for JUOMD mobile multimedia amplifier.Mike input USB jack.MP3 sound
SOURCE: rca jacks input
you need the speciall conector becous its a little problem your conections
Posted on Jul 04, 2007
Natahan
  • 24 Answers
SOURCE: PSP sound ouput
I'm pretty sure the USB port is only for transferring media files. I've searched my PSP head to toe and never heard of anything like that. I've found out you can use the USB connector on the white PSP to charge the battery. (I haven't tried that out yet.)
Posted on Dec 28, 2007
SOURCE: right speaker jack
The patch cable may be shot i had the same problem all i had to so was get a new patch cable (Best buy has them for 2.00) hope this helps
Posted on Jan 02, 2009
tech48
  • 624 Answers
SOURCE: receiver works with digital signal input jack only.
Are you talking about the 6 channel input with all RCA jacks? Please explain a little better, it is very hard to know how you have it connected without a very good description since I can not put my eyes on it. You may need to check the settings, it may have the rears muted. More information from you will help me to be able to help you.
Posted on Feb 06, 2009
  • 30 Answers
SOURCE: Can the a15 be configured to accept stereo input?
There are usb audio devices out there that would help you here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815144028
I'm not 100% sure that is exactly what you are looking for but it's a good place to start.
What you are looking for is a video and audio capture device that is USB compliant.
Posted on Jul 31, 2009
Does this unit have RCA line out jacks......
According to the specifications on the Clarion website it has:
  • 4ch/2V RCA Output (Front/Sub)
    So in answer to your question I believe it does have RCA line out.
Mar 07, 2011 | Clarion DB285USB Car CD/ MP3 Player
I have Polk Audio TSi500 speakers running through a receiver. They sound fine when the radio is playing from the receiver, but when I try to play music from a computer the speakers sound muffled. I have...
Phono jacks are specifically to hook up a turntable to an amplifier (which is what I assume you mean instead by "receiver" ). Most amplifiers have a receiver (radio) section, but they can be separate components. Anyway, try hooking it up to an auxiliary (AUX) input on your amplifier instead. This may be all you need to do. Good luck!
Feb 13, 2011 | Audio Players & Recorders
Hissing from computer speakers and they are new
Hello
A hissing sound indicates the speaker amplifier has no input from the computer sound card, check to make sure the speakers are hooked up to the correct port for audio out to the speaker input, the Audio output to the speaker is the GREEN mini RCA jack on the back of the computer.
Dec 30, 2010 | Bose Companion 2 Series II Multimedia...
I just unhooked my speakers to move them. i hooked them back up and i have no sound now.
Make sure you hooked thim into the correct jack. May be in the Mike or input jack. Done the same thing a few times
Aug 16, 2010 | Bose Companion 2 Series II Multimedia...
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
No audio input-have done system test,diagnostics. all report no problem but still no sound
Did you try feeding the audio line input jack with an MP3 (using MP3 headphone audio out) to find out if you do get sound? The volume control panel shows on the screen when you hit the Volume up/down buttons? Otherwise you may have power amplifier failure inside the unit ot it may lose the power supply feeding the amplifier.
Feb 27, 2010 | HP W2007 LCD Monitor
Does an mp3 player put out enough power for input to KAC-624 amp?
Have you connected the rca plugs to the radio or amp directly? If you've connected it to the radio make sure that the input level controls are adjusted AND available on that model (it will say AUX, INPUT, SUBWOOFER, REAR, etc.) Connecting your mp3 player directly to the amp will not have enough juice to hear sound you need to connect it to the radio first.
Oct 02, 2009 | Kenwood Car Audio & Video
Jul 31, 2009 | Computers & Internet
No sound at all
The jumpers are there to connect the preamp section to the power amp section and are required for the receiver to opperate properly. Make sure the receiver is set to the proper input, in this case: CD. If there are A/B speaker connections, be sure the receiver is set to match the connectors you're using. If there is still no sound, profesional service will be required.
Sep 26, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
