Question about Samsung Washing Machines
I have a Samsung washer Code No; 68-02834A-02-EN Error code nf I switched the temperature to cold/cold and it did work.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet-Error code F 02/wont spin and drain
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 09, 2008
SOURCE: I have a Maytag Model MAH8700aww washer
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on Dec 12, 2008
pride applia
  • 232 Answers
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
SOURCE: nf error code sporadically
Tell me, do you notice the water filling and going against the "glass" door and going straight to the overfill trap bellow the door?
Let me know.
Posted on Mar 08, 2010
  • 343 Answers
SOURCE: Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Posted on Apr 18, 2010
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What is Nf code
Dits a no fill error so you probably need to replace the water inlet valve. The link below goes into it in more detail. Samsung Washer Error Code NF Fixed
Oct 24, 2015 | Samsung SW62ASP Top Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
The NF light comes on
The nF error code stands for "No Fill."
If you have just installed your washer and it will not fill, or the display shows nF, check the following:
  • Make sure the door to the unit is tightly closed.
  • Make sure that both the hot and cold water lines are connected (cold to the cold and hot to the hot)
    • Note: If you do not have a hot water source, you can hook up the cold water source to the cold input on the back of the washer and another cold water source to the hot input on the back of the washer (but NEVER a hot water source to the cold water input on the back of the washer).
Oct 14, 2012 | Samsung WF337AA Front Load Washer
Error code nf
The nF error means that the washer isn't filling properly. Make sure that both the hot and cold water inlets are getting water flow. (You can get all cold water washes by connecting the hot to a second cold water line.) Make sure that you have opened the shut-off valves for both inlets to the washing machine. Check that there is sufficient water pressure on both inlets. You need 20-116 psi (pounds per square inch). Use the Samsung supply hoses. Some flood safe hoses may not work (even if new); when damaged, they can completely restrict the flow of water to the washer.
Take off the hoses. Check the filters both on the shut-off side and just inside the washer and clean then of any foreign objects. This is a good time to double check the water pressure at the shut-off valves (have a bucket under the valves.) Replace the inlet hoses if they are more than 5 years old.
Check that the drain hose is not lower than the water level in the washer. This can trigger suction causing the water to flow into the washer and straight out to the drain.
Make sure that the door of the washer is tightly closed. Then press the Start/Pause button.
If the error continues, the failure could be at the washer's inlet valve, the sensor that checks the weight of the drum + water, or the wiring or wiring harness to either one of these items. The computer control board can also fail to "hear and respond" to the above. If you have water in the drum with the nF error, start checking the sensor. If no water flows into the washer, check the valve first.
I hope this helps.
Oct 12, 2012 | Samsung WF337AA Front Load Washer
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
I get an NF error code and the washer sounds like it's filling, but never does, and then there is water in the detergent dispenser.
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. Try running the diagnostic test by:
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 22, 2010 | Samsung WF328AA Front Load Washer
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Try running the diagnostic test by—
Thanks
Rylee
Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
