Question about Garden
How many cc is my ariens st504 snowblower? It has a 5hp motor
  • 472 Answers
SOURCE: what make of motor is on my ariens st1032
Posted on Sep 30, 2009
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
  • 486 Answers
SOURCE: I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
  • 6 Answers
SOURCE: Snowblower seems weak for a 5HP
Check to see if there any surface rust inside the auger assembly. This will cause this problem. Also, you try a silicone spray on a painted surface.
Posted on Jan 06, 2010
  • 927 Answers
SOURCE: The rope on my recoil
Remove the recoil assembly from the machine, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Posted on May 02, 2011
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
Parts not available for Ariens ST724 snowblower?
No you do have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
I just bought a Ariens old snow blower Mod#ST504. It is 5hp. Mod# 932006, Ser# 023321. I need a new carburetor the only # I found on the 7389j7 it does not match any # on line?
You need to look at the Oregon brand of replacement parts as Tecumseh shuttered operations in 2009... Oh and those aren't Tecumseh numbers
Oct 18, 2014 | Garden
10 snowblower
Just a matter of the output shaft. If the height of the engine is slightly different, that can be adjusted by buying different sized belts But the Length and size of the Shaft that the Belt Pulley will be put on is the critical item
Dec 05, 2013 | Garden
Ariens st504 snowblower
I would suggest checking the flywheel and coil for rust on it as this is a common problem. There should also be a single wire running to the coil remove it and see if you have spark. If you still have no spark the coil may need changed.
Oct 23, 2013 | Garden
How do I change ariens snowblower belts
Oct 12, 2009 | Ariens Garden
Ariens Snowblower won't engage into drive
I had the same problem with my 5HP Dual stage (C950-520240) Canadian model and found that the arm connected to the traction cable (part #85449 "Shaft Traction Clutch") which forces the friction disk up to the rubber friction wheel had a cracked weld and had bent, preventing positive contact with the rubber friction wheel. The drive wheels would turn if you lifted the back of the machine off the ground, but would not work if under load. First I replaced the belt and rubber friction wheel, but no go. I had to basically disassemble the whole drive assembly to find the problem, very frustrating because you could not see the crack in the arm from head on. I had the cracked and bent arm straightened and welded, all is OK now. enb54.jpg
Dec 05, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
