Question about Coffee Makers & Espresso Machines
Coffee maker does not brew coffee. The light comes on when I start it and in couple of minutes it light turns green. No coffee and no heat under the coffe pot.
    Top Expert:
  • Coffee Maker... Master
  • 41,533 Answers
Would guess it blew up and needs replaced .
Posted on Dec 14, 2016
My Mr. Coffee JWX27 won't brew. lights go on and the machine clicks as if it is going to start but nothing comes out. I tried the cleaning mode with vinegar and water solution and still nothing.
The heating element has gone bad. It's time to replace your coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
Mar 10, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee won't brew - lights turn on - clock works - clicks little.
2 years old I would pitch and buy a new one.
Cleaning generally won't help a machine that does not work.
Heating element has probably burned out.
(I am not talking about the heating pad for the carafe!)
For future reference for all the coffee drinkers out there:
Simple quick way to clean a drip coffee maker is use Vinegar.
Let it brew through the system as you would water.
Discard and run fresh water through the system to clear out the vinegar residue left behind. (Make SURE the system has cooled first before running the fresh water through!)
For those that have hard water and the coffee tastes funny.
Try a small pinch of salt in the filter basket ON top of the coffee grounds. This will soften the water and hopefully take the bitter taste away.
Guess it is possible large enough calcium deposits could block the hole in the holding tank to prevent the water from percolating to the filter basket. You may wish to check this before tossing. Last minute thought before pushing the post button.
Oct 04, 2009 | Mr. Coffee TFTX85 Coffee Maker
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Display illuminates - but no display of time, etc.
My coffee maker is a Signature Classic and when I turn it on the light turns on but nothing happens. The water doesn't steam and the hot plate under my coffee pot doesn't heat up either, what's wrong I need my coffee?
Mar 24, 2008 | DeLonghi DCM485 Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Water does not displace...
if you give us the make and model we'll see what we can find for you.
Jan 05, 2008 | Bloomfield 8571 Coffee Maker
My DCC-1200 won't turn on
I called Cuisinart. There is no way to fix it. If your coffee maker is still under warranty (3 years) they will replace it. Otherwise, its next stop is the landfill.
Dec 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
