Question about Garden
How many ml to make up 5lt at 1.25 mix? - Garden
  • 1,913 Answers
If you want 1:25 mix, total 5 L, it works this way:
5 L is 5000 mL, so the oil needed is 1/25 of that which is 200 mL. This actually totals 5200 mL, but I'm assuming you start with 5 L petrol.
If you want exactly 5 L just add 200 mL oil to 4800 mL of petrol, which is almost the same.
Posted on Dec 14, 2016
    Top Expert:
  • Garden Master
  • 8,204 Answers
  • Brian Harris
    Brian Harris Dec 14, 2016
    Thanks
  • NOEL
    NOEL Dec 14, 2016
    your welcome
Petrol & Oil mix - one third of oil to 1 gallon = what in litres
You need to go by the oil to gas ratio. 1/3rd what?
Google 50:1 (or whatever) mix in litres
and you will find this
Google 50 1 mix in litres Google Search
Mixing ratios. For a mixing ratio of 1 : 50 you need 5 litres of high-octane gas and 0.10 litres (100 ml) of STIHL two-stroke oil.
Dec 03, 2017 | Garden
If I need to put 1ml of bioactive in my fish tank in 9 ml of water how much do I need for 7 gallon of water
There are 3785.4 ml per gallon. The rest of your question is ambiguous.
If you are saying that you mix 1 ml of bioactive in 9 ml of water for each gallon, then 7 ml of bioreactive in 63 ml of water.
If you are saying you mix 1 mi of bioreactive for each 9 ml of tank water, then your talking about 3785.4 / 9 = 420.6 ml (~421 ml). That does not seem right.
Sep 01, 2017 | Water Water Heaters
If direction for plant food mix calls for 15ml per 4 liters of water,what mix ratio for a 1650ml watering can?
1650 ml = 1.650 ltrs
the ratio of 15 to 4000ml(4ltrs) =3 : .0800 ml
8 : 1650 is the ratio
Jul 29, 2017 | Garden
How do I figure 10% of any given amount of liquid?
3 oz is 88 mL of paint
10 percent is 8.8 ml
Can you get a syringe from the chemist then you can suck up the hardener into it to 8.8 ml
it is about 1/2 a teaspoon
or 8.8 cc
Feb 09, 2017 | Garden
Fluid Measure
One US gallon is 3785 ml, so you need that much water which is 3785 / 50 = 75.7 measures (tablespoons).
So 75.7 tablespoons flour and 75.7 x 50 ml water = 3785 ml.
If you mean imperial gallons the answer is different, 4546 ml water and 90.9 tablespoons flour.
Jun 06, 2016 | Home
WHAT IS THE OIL TO GAS MIXTURE IN OIL TO GALLONS
Mixing
RatioGAS:OIL UNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.) *INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.) *INTERNATIONALOIL per 1 LITER Gasoline
(metric) 32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
May 04, 2015 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
Jan 01, 2015 | Weedeater Garden
How many ounces of oil do I add to gasoline to get a 50 to 1 mix?
Quite simple if the mix says 1:50 ( one to 50 ) ,it means for every one ounce of oil you add 50 ounces of gasoline.
If the instructions say 1/50 ( one of 50 parts) ,it means for every let us say 50 ounces of mix there are 49 ounces of gas and one ounce of oil.I use a one liter wine bottle !000 ml ,I put in 20 ml of oil fill bottle with gas and shake well-ps (mark bottle -hate to take a swig).If you are into avoirdupois system use 1 ounce oil add 50 ounces fresh gas .
Jul 26, 2014 | John Deere 2 Cycle Stroke Engine Motor Oil...
Fuel mixture on Homelite Chainsaw 330
Old 330 should be 25 to 1 (200ml to 5lt ulp)
some newer OPE oils like stihl 2st are 50 to 1 ,but use around 150ml to 5lt on old saws
Dec 21, 2008 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
