Connecting my rino120 to my computer, computer can not locate the device what's happening.
How do fix a new usb that says it is write proctected?
'usb' is just a type of port used on many devices to connect other devices. Are you connecting to a computer? Does the error message appear on a computer screen as soon as you plug the other device in? Is the device itself displaying a message? What does the message say?
It's important when you have a problem to tell people who might help you the following:
What type of device are you using? (and software system for a computer)
What action did you do, and what happens?
Does the problem happen every time you do that action?
Did the device work differently before?
Aug 04, 2011 | Computers & Internet
My pc cannot detect my maxtor one touch external hard disk
Please try connecting it to another computer. That way we'll know if the problem is with the computer or with the actual device itself ;) Let us know what happens or doesn't happen :(
Feb 20, 2011 | Maxtor OneTouch III 300 GB Hard Drive
Every time I hook up my mp3 player to my computer it doesn't recognize it, nor acknowledge that something is hooked up. The same thing also happens when I plug in my flash drive. In my device manager I...
Try the possible steps given below and check if it helps.
Remove all the connected USB devices including the Walkman Player.
Reboot the Computer and once it starts up connect only the Walkman to the Computer.
Please be sure that no USB Hub is being used to connect the devices.
Try connecting to different USB port on the Computer.
Press the RESET button located at the rear of the Walkman after connecting to the Computer.
Check if Connecting or Connected USB (MTP) message is appearing on the screen when connecting to the Computer.
Activate Windows Media Player 11 or Windows Explorer in the Computer and check if it is recognized.
After trying all the possible steps above and if the issue persists, then the issue may be with the USB Connector of the Computer or the USB Drivers. Try connecting the Walkman to a different Computer to check if the issue is with the Player.
Thanks for using FixYa
Dec 08, 2010 | Sony Walkman NWZ-E344 Digital Media Player
I plug my jump drive in to my computer and nothing happens, the light does not turn on and it doesnt show up on the computer, i have a very important paper i need to complete i need help now!!
Try connecting to a different USB port.
Try connecting to a USB port on a different computer.
If neither works, then your device has "failed". Permanently.
Nov 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Mp3 not recognized by the computer
try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
1- plug your mp3 in the computer using your usb.
2- go to my computer.... in the left task pane. click view systems information.
3-the system properties dialogue box will appear.
4-click the hardware tab then click the device manager.
5-the device manager tab will appear.
6- click the portable devices then you will see the name of your device.
7-click the name of your device .
8- you will see in the general tab in the dialogue box that will appear 'device usage'
9- enable it.
thats all..
Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
Every time i plug a usb into my computer nothing happens what is the problem?
First of all, which USB device are you connecting?
Check the status of your USB ports at your device manager.
Try different USB port.
Reboot your computer and try again
You probably need a driver if you are connecting unknow USB devices.
Oct 23, 2008 | Computers & Internet
Connecting to internet
The “Network adapters “is located in the”Device Manager” menu. If you clicked on” Device Manager” and nothing happens lets try to get to it another way. Go to “My Computer” which is usually located in the “Start” button, (lower left corner of desktop) and RIGHT click on “My Computer”. Another smaller window should open. Select “Properties” and another window will open. Select the “Hardware” tab at top select the “Device Manager” button.
If you have any other questions please contact me.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Latitude D600 Notebook
Wireless mouse
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
Loading photos onto computer
Unplug all other USB devices. Restart computer then plug it in solo.
May 20, 2007 | Samsung Digimax S500 Digital Camera
