Question about Consew Sewing Machines
How do I remove the bobbin case out of a consew 225?
    Top Expert:
  • Consew Master
  • 8,204 Answers
  • 4 Answers
SOURCE: tension problem, consew 225
I would go out and get a new bobbin case if i were you. I bet that screw is stripped out
Posted on Aug 06, 2010
  • 255 Answers
SOURCE: My husband purchased an old model Consew machine.
Check your manual to see which way the flat side of the needle shank should face. With modern machines, it's usually to the rear, away from you, but with older machines there was more variation.
The most common reason the needle won't pick up the bobbin thread is because the flat side of the needle is facing the wrong way for that machine.
Hope this helps!
Robbie
Posted on Aug 10, 2010
SOURCE: consew 230 machine, how to dis engage needle to wind bobbin.
I have an old Consew 230B and need an operating manual can any one help me. Thank you
Posted on Mar 23, 2011
SOURCE: needle hits bobbin case on consew 206rb
try these sites for video's & information
youtube
ehow
sewusa.com
fixsewingmachines.com
Posted on Apr 16, 2012
SOURCE: Consew 255rb-1 Problem is once a while the tread jame under the bobbin case. After sewing as started it can go on or if you stop and re-start it could be OK or it will start jamming again and have to
change the needle
clean under the needle plate & in the bobbin area for lint & loose threads
Posted on Apr 19, 2012
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Feb 06, 2016 | Consew Sewing Machines
My consew model 225 just had a new belt and oiled was sewing this morning and last night leather but will not pick up the bobbin thread just poking holes into the leather. Please help
Check bobbin threading and tension. Make sure correct needle is installed and threaded right. Belt and oil have zero to do with the problem.
Jun 28, 2014 | Consew Sewing Machines
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Needle hits bobbin case on consew 206rb
youtube
ehow
sewusa.com
Apr 15, 2012 | Consew 206RB
My husband purchased an old model Consew machine. It is mounted on a table and came with the instruction manual for models 225 & 226R-1. The machine will NOT pick up the bobbin thread. Any ideas?
Hope this helps!
Robbie
Aug 07, 2010 | Consew 226R-1
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
Looking for instruction to use the bobbin threader on a consew 206rb-2
Contact this company as they make Consew and will have exactly what you need.
WESTCHESTER SEWING MACHINE CO.
Phone; 800-225-8342 / 845- 627-8873
May 04, 2009 | Sewing Machines
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Sewing Machines Logo
120 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
