A clock set on five appears when I turn on loss vcr player
JMuskovitz
  • 135 Answers
SOURCE: setting the clock on my dvd/vcr
Here is a link to your owners manual: http://www.tacp.toshiba.com/tacpassets-images/models/SD-v393/docs/SD-v393_om_e.pdf It explains how to set the clock on pages 24-26.
Posted on Mar 25, 2007
Branrules101
  • 6 Answers
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Posted on Jun 15, 2008
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: setting clock on older VRDVD4001AC
According to the manual, to set the standard time, you should press VCR MENU, then SET + OR - to select System Setup. Press ENTER. Press SET+ OR - again and then choose STANDARD TIME followed by ENTER to set your own time zone. Press SET + OR - one more time to select your time zone, and then again press ENTER. To return, press VCR MENU twice.
Just a note: The unit is set to AUTO CLOCK when it is shipped. If you leave it this way, the clock will set itself after you plug in the unit provided you do not press POWER for at least three minutes when you first plug it in. Also, your cable box or antenna must be attached in order for it to find the time.
Posted on Nov 30, 2008
odlesrule
SOURCE: how to set up auto clock on a jvc vcr
When you have it on VCR mode you can bring up the menu and set the clock.
Posted on Jul 21, 2012
This is stupid but I lost my manual and can't figure out how to change the time on my Philips DVP3050v
I assume you wish to set the VCR (model DVP3050) clock. This is easy, just follow these instructions:
  1. Press VCR, then press DISC/VCR MENU so MENU appears. If the clock has never been set, the CLOCK SET menu may appear when you press DISC/VCR MENU. If so, follow the instructions from step 3 on this page.
  2. Press \/ or /\ to select CLOCK SET.Then, press >.
  3. While the MONTH space is flashing, press \/ or /\ until the month appears.Then, press >.
  4. While the DAY space is flashing, press \/ or /\ until the day appears.Then, press >.
  5. While the YEAR space is flashing, press \/ or /\ until the year appears.Then, press >. The day of the week will appear automatically.
  6. While the HOUR space is flashing, press \/ or /\ until the hour appears.Then, press >.
  7. While the MINUTE space is flashing, press \/ or /\ until the minute appears.Then, press >.
  8. While the AM or PM space is flashing, press \/ or /\ to point to AM or PM. Your selection will flash on the screen in the AM/PM space.
  9. Press CLEAR/RESET or > to start the clock.
And you can now have an online manual, click here. (Adobe pdf required) Directions on page 22.
Lots more Info
Nov 07, 2010 | Philips DVP3050V/37
How to set up auto clock on a jvc vcr
Nov 25, 2009 | JVC HR-XVC27U DVD Player/VCR
I HAVE A PANASONIC VCR ITR WORKS FINE, BUT THE
If you go into the menu you should see clock setting,there will be manual or auto,set to auto and the clock will set its self,even if the vcr is turned off.
Oct 09, 2009 | Panasonic DMR-E75V DVD Player/VCR
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
The clock on my VCR/DVD recorder will not keep the correct time. It goes back one hour repeadedly after setting.
You`ll probably find that the PDC (Program Delivery Control) is turned on. If you turn this off, the autmatic clock setting will be disabled and will have to be set manually. Ian
Jan 21, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Setting the clock
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
