Question about Bionaire Heating & Cooling
My bionaire heater is a 225k 250v .how do i replace a fuse?
2 Suggested Answers
klhjbewgvrw
SOURCE: Looking for a replacment fuse #T3.15AL 250V
The cheapest place I have found is amazon. here:
QUALITY USA brand fuses Set of 5 pieces T3 15AL250V T3 15A 250V T3 15L250V... (you can search from another sellers, but this one had most positive reviews). I hope this was helpful. cheers
Posted on Nov 29, 2014
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
How to change remote control battery for a Bonaire heater
The remote for Bionaire® 20" Ceramic Mini-Tower Heater with LCD Control uses BUTTON cells (Disc type, 3 volt, CR2025)..
Open the remote as shown in page 4
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-bionaire-ca-Library/default/dw869fb9a8/documents/instruction-manuals/BCH9208-CN_EN.pdf
Jan 12, 2014 | Bionaire BT200RCU Tower Fan
Bionaire bfh5000um just blinks when i try to turn it on?
Do you have the owners manual it should tell you
Try looking up the mfg with as search engine
www.bionaire.com/
Oct 19, 2013 | Bionaire BFH5000UM Electric Heater
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
I have an Bionaire BPH1520 Micathermic Electric heater which will not heat up. I turned it off after use and now will not heat up when switched on. Digital display still lights up? Is there an internal...
AUTO SAFETY SHUT OFF
The heater has a built in safety device which
will switch off the heater automatically in case
of accidental overheating. It can only resume
operation when the user has reset the unit. For the
BPH1520 (OH)will display in an overheat situation.
To reset the heater:
1. Unplug the heater and wait for 30 minutes
for the heater to cool down.
2. After the 30 minutes, plug the heater in
again and operate normally.
fOR FUTURE REFERENCE HERE IS A COPY OF THE OWNERS MANUAL
http://www.bionaireuk.co.uk/Manuals/MANUALS/BPH1520-UK_43_91313392.PDF
Jun 07, 2011 | Bionaire BPH1520 Micathermic Electric Wall...
Remote for BFH3430-U
It is made by Holmes and like you I cannot find their heater parts - I wonder if it is not due to fire hazard by home repair
Jan 05, 2010 | Bionaire BFH3430-U Dehumidifier
Fuse
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Aug 03, 2008 | Belkin TuneBase FM (F8Z049-BLK) Car...
Heating & Cooling Logo
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
richie46
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
